100KM
Hi all
Maybe I'm doing something stupid, or don't understand something, but on my simple flight plan this morning I had a 3 turn loiter command. When my plane reached the position, it simply kept on circling, never exiting even after 6+ turns.
Did I do something wrong in my flight plan?
I'm attaching both tlog and waypoint files.
Thanks for any help. I'm flying V2.28.
V2.28
2012-03-14 10-00-34.zip
Mil Pano.txt
  • 100KM
    I've tested time based loitering, which works perfectly. I'm going to log a bug. Ok, scratch that - I see I'm behind on my version again (2.8)!
  • 100KM
    Can somebody at least confirm that their Loiter Turns is working correctly?
    You do know that there are three types of loiter commands, don't you?  1 - Loiter unlimited, 2 - Loiter x turns, 3 - loiter x time.  If you are using the first you will never leave the loiter.  Generally that command is used to end a mission, or in conjunction with a conditional command.  The other two loiter commands you specify a number of turns you wish to remain in the loiter, or an amount of time...
