Hi everybody,
i thought i might do a post on some feature that most people may not know about. so here goes.
1. HUD, if you double click the hud it will popout, allowing you to run the hud full screen, on a seconds screen.
2. Tuning, if you enable tuning and double click tuning you can graph any data that is availbale in the status tab. this means you can have alt, attitude, or many other options. in real time.
3. Speed Guage, double click this and you can modify the max scale you want to display.
4. Nmea output to serial port, press control-g and you wil get a box asking for a comport and baud rate to output standard nmea data at 2 hz, to any serial port. ie use com2com to emulate a serial port to use with third party applications.
5. Custom imagery, press control-F this allows you to upload your own orthophotos. use will require Globalmapper, as this is currently one of the key steps in exporting in the required format for use in the planner.
6. Prefetch, this is on the flight planner tab and allows you to draw a box to download the selected imagery of a location, so you dont require internet while your at the field.
7. Grid, this is on the flight planner tab to, this allows you to draw a polygon (right click) and automaticly create waypoints over the selected area. NOTE there is no island detection, other advanced polygon features.
8. Setting your home location to the current location is easy, just click "Home Location" above where you enter your home location, and it will set your home location to the current coords.
Hopefully you find some of this useful.
Michael
in the flight data tab, there is a tick box down the bottom under the map called tuning. tick that.
Hi Michael,
Thanks for a great, and free, product.
I've picked up a small problem with the latest update though.
My 32bit XP pro machine, that has zero battery life updated fine, yesterday.
This morning I took my 64bit Win 7 Pro machine, that can run for 4 hours to the field, and since I had a high speed 3G link, did the update.
And it didn't work.
Uninstalled the program, and downloaded the "Latest" using the link.
Five tries, and it came up with "this is not a valid MSI" whatever.
Am I the only one ?
Gustav
Michael
Just a quick note to say the SHOW MAP feature in the Log Browse screen is legen.... wait for it...dary!
Is that a new feature, or have I just missed it all this time?
Great work!
Thank you for all your hard work.
Should I put this on github?
Mmm, possible bug?
Michael, if I set up a mission, and then assign a function like "Do_Set_Servo" to a waypoint, that waypoint disappears from the screen when I save the mission file.
Actually, this was reported to me by a friend, I tested it, same problem here.
It doesn't get deleted as such, if you assign "Waypoint" to it again, it comes back, but if you were to do this to non sequencial waypoints, the display reflects an entirely new mission.
Gustav
Hi Michael,
I don't know if I can use this discussion to still include suggestions ( I was out a long time, don't know if there new rules/places for suggestions). Anyway:
Mission Planner (flight Plan), Auto WP menu options, the suggestions is automaticaly created
spiral ascendent to the plane climb to a final altitude (spiral_ascendent(number of points per turn, final altitude, climb rate/angle?).
The same for spiral descent.
See attached image example.
regards,
Omar
regards.
Hi Michael,
Thanks again for your efforts here.
A question, I would like to set up a mission that starts at one position, and end somewhere else, so no "Home".
We have an annual "Long Run" event for charity, 100 Km !
Interestingly, it requires only 19 way points, to be have the aircraft within visual range of the road along the complete route.
Gustav
Longrun2011.kmz
Longrun2011.h
Good job on the update. I like the new parameter screens.
Why not with the Alt Guage as well? I rarely fly at 100m.
Thanks Michael,
The latest MP really is a thing of beauty!
1
2
3
4
of 4 Next
