APM PRO MINI - connecting usbavr programmer
I have the new apm pro mini from china. Had it working great until it stopped connecting. All I have is a solid green power and no action lights. Assuming ive bricked it, I've been everywhere on the net to see how to flash the bootloader etc. But all I can find is instructions for the 2.x mega board. Im not sure where to connect the usbavr adapter pins to access the bootloader. I'll include some attachments of the board and what info I was able to dig up. I've contacted the seller and they've agreed to send a new one, but I would like trying to fix it myself as it is 30days to return and then 30 more to get the new one. Ive already purchased the 10pin to 6pin usbavr adapter which I assume is what I need, I just cant figure where the pins attached to. Any help would be great! Thxs.3691234732?profile=original3691234594?profile=original3691234802?profile=original3691234747?profile=original
  • Hi,
    did you have lucky ?
    Mine is in same situation.
    • Adruino IDE open now what? Not use before. I try with avrdudes and not work. I have stk500v2mega2560.hex and
      Stk500boot.c files, which one and how to flash with arduino ide? Almost there...
    • In. VCC-MOSI-GRND Out
      . O O. O
      . O. O. O
      . MISO-SCK-RST
      Are all pins used?
      • Hi
        first, after connecting USBASP you must on arduino IDE reflash the bootloader.
        Then, remove usbasp and using USB cable plugged on usb port open mission planner and on Initial Setup/Install firmware.
    • What .hex file and please attach link to file, I am ready to flash but I don't know what hex to use.
    • Wow, I've been waiting for over 5 months to a solution to this problem. If it works for me I will be greatly appreciative. Can u post a diagram or mapping for what pin goes where? It is hard to see in the photos...much thanks!
      • Up Border of board with RC inputs on your left side - my thumb
        VCC - MOSI - GND
        MISO - SCK - RESET
        Remember - USBASP must be 3.3 Volts - you will be flashing the microcontroller directly
        First I was finding all pins and then look at connectors - on my mind, somehow the manufacturer must flash the firmware after the board ready, so must be a connector somewhere - and exists :)
        So I soldering some jumpers wire, connecto to my USBASP programmer, flash the bootloader and reflash Arducopter firmware, after reboot the board and connect on mission planner I remove the wires - be carefully with solder - the pins are very close
    • Hi
      After some research, I found the ISP pins.3702608661?profile=original
      and the order of pins are on next píctures.
      After connecting usbasp and burning bootloader I could flash again software and the board is ok now.
      Regards.
      3702608577?profile=original
      3702608702?profile=original
      • i have some problem with my APM Pro, when i try to download datalog, the mission planner doesnt working, have you any suggest to fix it ?
        Best Regards Dani
        3702739057?profile=original
