APM servo reversing
I am setting up a APM with a F27 Stryker that uses elevons. I am working with code revision APM 1.0 Public Beta. I have everything working well in manual mode and I used the reverse dip switches to get the controls to react properly to the transmitter in stabilized mode. The issue I have is that in stabilized mode when I pitch the APM reacts with one elevon up and the other one down which is wrong. When I roll the plane it reacts with both elevons going up. No doubt the solution is to reverse one of the servos but I cant figure out how to do that. I have been using the config
#define REVERSE_CH1_ELEVON        0
 I have been putting this into the APM_Config.h tab.
I have had similar trouble trying to reverse the throttle. From what I can find the command is
#define THROTTLE_REVERSE    0
I also define this in the APM_Config.h tab with no success in reversing it.
I know this is a simple thing but I spent the last 2 days scouring the forums and trying things on my own with no success and I am going a bit crazy at this point. This is the final adjustment I need to make before I make my first flight so I am very excited to try it out!!
    You should be able to do all the servo reversing with the DIP switches. Sometimes it takes a little trial and error. I've tried to show a typical delta wing setup in the manual.
    As for Throttle, the way to do it is to change this in the config.h file:
    # define THROTTLE_REVERSE DISABLED
