I really hope I'm not missing something obvious.....But is there a way to reset ALL settings to default? I was thinking of flashing my APM2.5 with a plane's code, and then back to quad. But that would reset the camera gimbals settings would it?
Found it, here's the information in the wiki. The command you want is probably 'reset' which you can get to from the 'setup' command.
http://code.google.com/p/ardupilot-mega/wiki/CLI
You can erase all of the parameters using the CLI. The command is 'setup', then 'erase' if I remember correctly. The wiki should have this information as well. Someone correct me if I'm wrong but even if you flash the firmware the parameters will not be erased.
