What are the advantages and disadvantages or each?
The PX4 looks like the very old days when APM had many boards and no case. Just looking at the advertisement I have no idea why I would want to trade in my APM 2.5+ for a PX4?
Anyways all my gear seems to be in perfect order, havent tested the IOAR board yet as I need to solder in the power cable and various headers. But was able to run px4flow fully in QGC and was able to build and flash latest release of px4fmu firmware onto the board and it responds as expected.
I got the px4flow, got it up and running in QGroundControl in calibration mode with mavlink, and I am getting the picture as well into the HUD view so it's def working OK. Had to manually force win7 to install the driver though. It appears as a standard mavlink device, and exposes all kinds of settings direct in QGC plus of course feeds back all the gyro rates, sonar distance and also flow/camera angle and a bunch of other data that I didnt yet dig into. Good thing it also gives the sonar by default so we can use it directly for altitude hold when low enough.
The DF13 6pos to 5pos was included in the PX4FLOW baggie, so it will connect to UART5 on the PX4IOAR straight with that cable - nifty.
2 slight downers sofar, the M3 nuts for attaching the whole thing to the AR drone cross were missing so I havent got it all mounted yet, and for some reason I am not able to get any action other than LED's on the PX4FMU sofar. I think I need to flash it first but I would have expected some version of the firmware to be on it for testing at factory, but maybe they put something else on for that.
I will be making a blog of the general 'build', got tons of unboxing pics also ready.
But yep Gary, we seem to be some of the first on here to jump on the PX4 bandwagon so I will let you know anything I find of use for the flow to add to wiki, and also for the fmu itself. It will take a few weeks I guess for the FrSky stuff to get here so I can't get it up in the air just quite yet.
@Gary,
I think the rubber standoffs are included in the PX4IOAR package rather than the PX4FMU package, I will confirm or not in a few hours when I get to unboxing my kit.
Did you also get the PX4FLOW? I see you did add some info about it on the wiki. Still slapping myself for forgetting to order the 6 pos cable, but I am not 100% how to connect the two together... I am guessing some kind of custom Df13 6position to DF13 5pos + power is needed, but I can't seem to work it out from the documentation, did you figure this out yet?
I also got the px4flow at the same time.
Will be adding some infos as I get it up and running, still need to wait for the frsky stuff to come from HK before I can try to fly it.
I have now included introductory Overviews of the PX4-IO board here: https://code.google.com/p/arducopter/wiki/PX4IOboard
As well as the PX4-FLOW camera boards into the Arducopter Wiki here: https://code.google.com/p/arducopter/wiki/PX4FLOWcamera
Also unless I misunderstood, to use the existing APM code on the PX4 it must be run in an 8 bit emulation mode for now making the performance gains very limited compared with a native 32bit port.
+1 @ Gary McCray
Lorenz, the PX4 looks to be a well engineered piece of technology. Clearly allot of thought has gone into it's design by people who know what they are doing.
Time to bring this thread back to the original question and wrap up some relevant facts: PX4 is not just yet another autopilot platform, instead we did some things quite differently.
Some general remarks on PX4:
On robustness:
Some comments on RTOS aspects:
About the safety, I have a design flying around which I wanted to blog somewhat soon. I started drafting it after reading the heated discussion of dronesavant about 3DR staff flying to close to spectators and stuff...
The idea is to have a board with (solid state-) relais that - when RC-activated - physically and unoverrideable cuts the power to the motors and requires to be reset by a button on the device itself (i.e. impossible to reset via RC). It could additionally have an output to trigger a parachute if necessary. The idea is to have some kind of panic button just in case the 3, 4, 6 or 8 meatmincers come too close to anything living.
1
2
3
4
5
of 5 Next
