  • This may work as well...
    Telemetry Distribution Board
    Bluetooth telemetry
    Long range telemetry set for all your UAV and UAS needs
  • When I connect minimOSD AND telemetry with APM2.5 (using Y conenctors), I can have both working, telemetry and minimOSD for a short time (I see all the values and the Mavlink symbol pulsing).
    But after 3-4 minutes, the signal % of telemetry reported by MissionPlanner starts to decrease and at some moment MP says "No data for...4 min, not data for..". I did double check the conenction between telemetry and minimOSD and I have 3 wires only as per wiki. So it is working for few minutes and the I loose the telemetry connection. MinimOSD continue to display the Mavlink data correct. MinimOSD is powered by APM2.5 from telemetry with 5v and also with 11.5 v on the other side with camera. I have both 2 red LEDs working. I also reset minimOSD from the button, does not help.
    This happened since I start to use APM2.5. I did not have this issue on APM2.0. Any sugegstion, please?
  • You can make a simple splitter like CyberCrash showed. This is also a nice diagram of using 3DR w/ OSD and I/O board. jDrones is supposed to be making a nice little board for this purpose, though no one will tell me when it will be available.
  • my solution:
    3692639272?profile=original
    see http://code.google.com/p/arducam-osd/wiki/minimosd
    Typically most people run FPV or Telemetry (since you cans see the info onscreen in FPV ;-) ) If you want to run both you will need to mod the cable from the APM to your MinimOSD & Telemetry radio
  • There are plenty of posts on this site concerning your question if you would search for them. Good luck.
