APM2 SPI and Optical Flow Sensor
Does Anybody know if there would be a respin of the APM2 daughteboard in order to include a three pin connector or some other easy access to the SPI pins without soldering the cables for the optical flow connector?
I am ready to order APM2 however would wait if that mod happens soon.
Patricio
  • It seems that the only way as of now is to do the soldering on APM2, it is mentioned on the WIKI page of OptiFlow
    Comment by project member rmackay...@gmail.com, Apr 25, 2012
    hilltopflyer,
    The original hope with the APM2 was that you could just plug it in instead of having to solder anything but sadly we found a problem after the APM2s had already gone into production re interference with the MPU6000 (they both work fine when tested individually but not together!). The only way that I've been able to get the sensor to work with the APM2 is to solder it as shown in the pictures above. It is fiddly but very possible.
    I have done the soldering and found that the best way is to use a JST connector (I used what was available with me 4 pins, it will be better if you have 3 pins).
    Photo 1: The JST connector and APM2 before soldering
     3692446016?profile=original
    Photo 2: The APM2 after soldering the JST Connector
     3692446114?profile=original
    Photo 3: Preparing a cable to connect APM2 (MISO,MOSI,SCLK) to OptiFlow Sensor
     3692446160?profile=original
    Pohto 4: OptiFlow Sensor connected to APM2
     3692446037?profile=original
    Remember that you will need firmware 2.6 to be able to use APM2 with Optiflow sensor. Also I noticed that testing sketch that is posted on the wiki is not working as expected (giving white pixels) however the test from APM2 command line is working perfectly.
