Version 2.4 of the ArduCopter code is now available in the AP Mission Planner and in the downloads area. Although not as big a change as the 2.3 release, it still includes a respectable number of enhancements and bug fixes.
Enhancements:
- massive reduction in memory use (>2k saved!) due to Parameters change and APM2 baro lib fix. TradHeli code can again advance in hand with the quad code
- improved throttle range in stabilize mode. You may find that it takes slightly higher throttle than previously during hover but hopefully you'll find that you have more useable range of the throttle stick as well.
- added TUNE_LOW and TUNE_HIGH for CH6 Tuning (I.e. to set tuning range between 2 and 6 set TUNE_LOW to 2000, TUNE_HIGH to 6000)
- new ACRO_P gain for those who like to fly in ACRO (aka Rate) mode
- Loiter improvements including scaling of X speed
- Easier to use motor testing. see the videos for quad and octa-x-coaxial.
Bug fixes:
- remove unnecessary block for next GPS value before saving home location
- remove wobble on take-off
- turn off camera pitch control (which uses channel 6) when using channel 6 for tuning
- reduced rate of decent when landing using sonar
- Add support for CH_10 and CH_11 for APM2 users
- fixed Log_Read_Control_Tuning so that it doesn't read too many bytes
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P in 25% steps.
Thanks go to the numerous contributors including users and their detailed bug reports, developers and testers. Hopefully all together this will add up to a nice smooth release!
As per usual, please post your comments, issues in this discussion. For enhancement requests for future versions, feel free to add them to the issues list. Note: you can "star" an issue to receive emails when someone comments on the item. On the dev side it helps us because we can get an idea as to which feature requests are the most popular by sorting by the number of people how have starred each issue.
hello, are we safe to use for hexa or should we wait for next version? ive just got myself a photohigher gimbal and would hate to crash this.
paul
Hey
ive uploaded 2.4.1 and tested my Hexa in the Field. But it isnt stable in Loiter. So i investigated the problem and saw, that my Gyros seems to be not okay. So i have to ask. For me is it so, that the Gyros should be zero, if i dont move the Copter. But they dont. Look at the Pic.
The ACC Values (ax, ay, az) are moving too. So, if havnt movement, i shouldnt have an acceleration, or?
Is it normal ?
Test 2.4.1 loiter and Guided
Hello All,
I've done some pre-flight tests today with latest GIT version.
It seems there is something wrong with baro on this version.
When I arm the motors alt is set to 0 then rise slowly, (my quad stay on the bench).
If I disarm the motor and arm again alt is reset to 0 then rise up again.
Here is what I get in mission planner:
It was not the case with 4.2.1 firmware.
I've also attach 2 log file.
I have not made a test flight.
Let me know if I should open an issue.
Olivier
2012-03-13 04-52 2.log
2012-03-13 04-51 1.log
So, what's the deal? Is the DCM or quaternion approach being used currently? How is the filtering scheme with quaternions performing in it's handling of noise/vibrations? I see the quaternion additions in GIT, hence the questions.
Thanks dev team,
I didn't try to compile using Arduino before. But i am about to try to do so i can use the GIT release.
My question is, Where is the part that i can define the layout of my copter? Quad, Hex, Or octa?
Thank you.
Just ran 2 batteries through on my jDrones Hexacopter (880kv, 30amp) with APM2 (git tag: 6cd49a35c130e - the yaw from Tridge). Its much more stable for me than the last few attempts - which were very jittery to say the least.
Windless here, and I manage several hovers with very minimal stick input (not loiter - just nicely balanced). It did pick up a persistent lean to the left, countered with a little right stick - but nothing like as bad as I've seen before. I'm back to mounting the APM on rubber washers onto a board - not suspended on O-rings - maybe thats the cause. Like I said though, its nothing like the '100% stick the other way' stuff I've had in the past.
This was just hovering in the yard - tomorrow, I'll head out to a field and try loiter. Really hoping to see a similar improvement on that ;)
Thanks Guys! Great work :)
Oh, and another rather annoying thing I noticed with git release 94c14cef91ab : I cannot connect to mission planner anymore with my wireless connection (APC220). Annoying cause now I can't make tlogs anymore for debugging. I think I saw this problem pass by earlier in this thread, but can't seem to find it anymore. Anyone know what might be wrong ? I checked baud rates, they are set at 57000 in both planner and ACM, which seems correct
About the yaw problems, I see Tridge has just pushed a fix to git : 60a6c80614b2 . Thanks for all the work guys !
