With the new ArduCopter code, it is possible to set the RADIUS to 0 allowing the aircraft to rotate on a single axis for panoramic images etc.
It it possible to set the amount of rotations the aircraft can perform before returning to its initial position.
For example, if the aircraft is pointing north when CIRCLE is first engaged with a 0 RADIUS, it would be ideal if a parameter could be set for the aircraft to perform 1 complete rotation before returning back to its North position and holding. If changing mode back to away from CIRCLE and then back again, it would restart the rotation again.
If the parameter was 2, it would complete two complete rotations before returning back and holding again.
Any views?
