ArduCopter 3.2.1-rc2 (release candidate #2) has completed beta testing and has been released as the official version available through the mission planner and other ground stations.
Changes from AC3.2 are listed below and in the ReleaseNotes:
1) Enhancements:
a) reduced twitch when passing Spline waypoints
b) Faster disarm after landing in Auto, Land, RTL
c) Pixhawk LED turns green before arming only after GPS HDOP falls below 2.3 (only in flight modes requiring GPS)
2) Safety Features:
a) Add desired descent rate check to reduce chance of false-positive on landing check
b) improved MPU6k health monitoring and re-configuration in case of in-flight failure
c) Rally point distance check reduced to 300m (reduces chance of RTL to far away forgotten Rally point)
d) auto-disarm if vehicle is landed for 15seconds even in Auto, Guided, RTL, Circle
e) fence breach while vehicle is landed causes vehicle to disarm (previously did RTL)
3) Bug Fixes:
a) Check flight mode even when arming from GCS (previously it was possible to arm in RTL mode if arming was initiated from GCS)
b) Send vehicle target destination in RTL, Guided (allows GCS to show where vehicle is flying to in these modes)
c) PosHold wind compensation fix
d) prevent infinite loop with do-jump commands pointing at each other
e) pixhawk memory corruption fix when connecting via USB
f) vehicle stops at fence's alt limit in Loiter, AltHold, PosHold (as it did in AC3.1.5)
g) protect against multiple arming messages from GCS causing gyro calibratoin failure
Thanks to Raph for the video. This is actually a video from AC3.2 until we have one specific to AC3.2.1.
Sorry for asking this question late. What is PosHold wind compensation fix? Was there any issue with that flight mode earlier?
Randy / Devs
I have noticed that when in pos-hld if I left go of the stick while it's moving forward [ say 5mps or above ] it glides to a stop but then returns several feet. Is there a way to have it glide to a stop and stop there and not return? It's like it tries to return to where it was when you left go of the stick not stop at where it's forward motion ended. I find this hard to fly in a small area with obstacles. Is this related to the braking setting? Is this at all what was addressed with the wind compensation fix? I haven't had a chance to fly rc2 yet. Thx
ArduCopter 3.2.1-rc2 is ready for testing and you can download it from the MP’s beta firmware’s link. The list of changes from -rc1 is:
1) Bug Fixes:
a) prevent infinite loop with linked jump commands
b) Pixhawk memory corruption fix when connecting via USB
c) vehicle stops at fence altitude limit in Loier, AltHold, PosHold
d) protect against multiple arming messages from GCS causing silent gyro calibration failure
The last item #1d was causing the “pitch drift” reported by Itay (and also Marco) and we’ve determined the cause is the MP is sending two arming messages to the copter which were interfering with each other. We now reject the 2nd one which unfortunately leads to a confusing message, “Error: command rejected by MAV” but the vehicle will indeed arm. It’s safe to ignore this message and I suspect Michael O will release a new version of the MP which resolves this in a reasonably short period of time.
If all goes well we hope to release this as the official AC3.2.1 release next week.
Randy,
this is for APM and Pixhawk or just pixhawk? On item 1C, does the vehicle stop and return or it just still fly and wont go any higher than the limit?
thanks
1c is just a fix to make the fence work the same as in AC3.1.5 in that the vehicle stops at the altitude limit if the vehicle is in AltHold, Loiter, PosHold or Sport modes (modes where the pilot controls the altitude with the throttle stick).
For AC3.3 or AC3.4 we will likely have the vehicle also stop at the fence perimeter in these manually controlled flight modes. When we do this we could probably add a parameter to allow choosing the behaviour when it hits the fence (i.e. stop or RTL). We probably always want the vehicle to RTL if it's in AUTO mode 'cuz we wouldn't want the vehicle getting stuck out on the fence.
Thanks!
P.S. when I say "stops at the altitude limit" I mean that it stops climbing. It will still keep moving horizontally in the direction you push it so I think it will do what Thor is looking for.
Thats the way ahuh ahuh, i like it ahuh ahuh!! thanks for the reply Randy!
thanks yeah i hope the same, i like the idea of a ceiling but i hope its just wont stop once it hits the ceiling but continue to fly in its direction. good way to maintain a proper altitude, imho
I'm leaning the other direction on this. I have my fence set strictly for safety purposes. For me, if it hits the fence, it needs to RTL or Land because something went potentially wrong. The idea of having it helplessly stop at the fence and stay there till the battery died doesn't sound nice at all. Perhaps a dual purpose fence option depending upon what one is using if for?
Today I want to check my new fpv equipment in my older cuad, i know that I have to recalibrate compass but only flies near me and low altitude, the copter changes unexpected to land, i didn't know what's happen, and now I find in the instructions here http://copter.ardupilot.com/wiki/ekf-inav-failsafe/ I didn't remember this interesting failsafe to avoid fly away, works perfect (accidentally another check for this release) Thank's guys.
Craig.. Just fyi I had two crashed because props broke. I guess no wonder they were cheap ones on eBay like this [ see link ] . I threw about 40 of them in the garbage. The first time I thought it was a fluke. The second time I had just came back from flying way out over the ocean... it was 20 feet up over a tree and almost home when it broke. very lucky! There was zero warning it just snapped near the inside. Anyway just thought I'd mention it I don't know if that was your issue or not. But if anybody reading this has cheap china nylon props throw them out!
http://www.ebay.com/itm/8pcs-10x4-5-1045-Nylon-CW-CCW-Propeller-Pro...
32
33
34
35
36
of 44 Next
