ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • He was referring to APM.
          However, PIXHAWK is indeed becoming insufficient already - a faster CPU and especially a second core would be very helpful in terms of being able to do what Paul wants to do with the EKF. Copter is currently struggling to keep main loop times down to 2.5ms, but does seem to be successfully running at 400hz. EKF could better handle hard IMU failures if it had more CPU - what I gather is that we almost need to run two of them, one for each IMU.
          • And what about running the fast_loop at only 200Hz or even 100Hz with the Pixhawk, just like the APM?
            We need a refresh rate in line with the copter dynamics and, even if 400Hz is anyway much better than 100Hz, maybe the 100Hz is fast enough for most cases.
        • he is talking about APM...
        • I believe they mean they are running out of flash space on the APM. I could be wrong but without getting rid of the CLI then 3.2 would not have been available to those with the APM. Pixhawk should be good on flash space.
      • Thanks Randy. I found the download section. I was wondering how you now enable/disable items, i.e. imu, att, ctun, etc..
          Barrett,
              Aha.  So it's possible to use the drop-down in the standard params screen of the mission planner to set the LOG_BITMASK parameter but the user doesn't get complete flexibility in what logs are enabled disabled.  So we need a new feature in MP which allows more fine grained control.  Issue for MP added!  Thanks for the report.
  • Nice, it's best then ever! Congrats guys!
