Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Hi Christian, Thanks. i really don't know because warning #2 says "if two spline waypoints are created one on top of the other". In my case, the waypoints are far from each other. Anyway, they might be related and hopefully fixed in rc3.
> here is comparison of LEA6(red) and M8N(blue) (behind the house)
wow ... amazing. I am assuming HDOPs also followed that trend.
So just to be sure, you used the M8N from csgshop with "stock" GPS+glonass antenna?
I wonder how the M7N will compare to the M8N with upgraded GLONAss antenna, in the US ...
sorry forgot hdop. yes stock antenna from csg.
LEA6(red) and M8N(green)
Outstanding ...
Thanks for posting these logs.
So if you like football, 3.2 can do the ball game too, otherwise trimming the hedge :-)
Randy, did you investigate that glitch behaviour happened in your youtube video?
Raph I got the same error during log download over mavlink.
Wow there are so many Mavlink Bad Packet (crc fail) messages in debug console... now I know why connecting via mavlink is sow slow since I use a pixhawk. APM has no problems. Fast connection as usual. My SiK firmware is 1.6.
Marco had same issue some weeks ago:
http://youtu.be/ZrihdM0txdw
Somebody said:
"If you untick ECC on both modules that should solve the issue.."
So I'm going to test that tomorrow.. Hopefully this is not caused by serialport or gps settings.
Hi
LEA6 setting: GPS_TYPE=2(ublox); connected to GPS port; factory settings overided by pixhawk boot
M8N setting: GPS_TYPE2=2(ublox); connected to Serial4/5; didn't check if overided, but elevation set to 10°, SBAS off
@terry, i meant the digikey antenna. sparkfun was written inadvertently.
When i use the pixhawk testing 3.2rc2 i found two bug
1.Running 3.2rc2 without any peripherals, just use usb connect pixhawk.than pixhawk running good and leds hand yellow double flash.But after a period of time,leds stop flash and FMU froze.If i connect full of peripherals(Safe key,GPS,Power module),it just running gread,and never froze again.
2.When the Channel 7 or 8 choose AutoTune, and then use the mission planner do radio calibration pixhawk froze.
sorry my English is not so well, all those use google translation.
hi,
1. I've only seen pixhawk freezes when GPS or other UART(Rx/Tx) devices were connected in reverse(Tx/Rx). So I can't imagine the reason, perhaps it could hang if an auto detection routine went into time-out if nothing was detected.
2. maybe you reversed RC-in and SBUS input? It would be great if you could upload a picture of your wiring.
