Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Frank,
hmm.. it shouldn't have been necessary to set the device ids manually. It should have done that for you when you did the compass calibration so that's a bit odd.
The compass-mot thing is a remaining to-do item. It'll be there for -rc4.
Thanks for the report and your testing!
Hi.
Im trying to compile RC3 in ArduPilot-Arduino-1.0.3-windows for my tricopter but having trouble.
I have a SSG gimbal so i need to change the servo out for the camera mount, so i need to compile it myself.
Arduino says that the "Sketch is too big".
I have a APM 2.5 and i loaded "Arducopter-beta / Copter: update AC3.2-rc3" from github.
Any one have some ideas?
You have to disable some features in APM_Config.h
https://github.com/diydrones/ardupilot/blob/master/ArduCopter/APM_C...
Mind to keep a sketch size < 242kB, otherwise you risk to burn your APM.
I have try to disable everything except gimal and poshold flight mode.
And the sketch is still too big!
Binary sketch size: 259 044 bytes (of a 258 048 byte maximum)
Is this normal?
Do i have the correct file? I saw that there where a file named APM2, is that for APM 2.5 or only APM 2?
Have you tryed with this new version of compiler, it makes smaller sketch sizes?
http://dev.ardupilot.com/wiki/building-ardupilot-with-arduino-windo...
I using this one.
http://ardupilot.com/downloads/?did=45
Is it the same?
The link to the arduino.zip that you sended doesn´t work at the moment......
I found and installed Arduino 1.0.3-gcc-4.7.2 and arducopter 3.2-RC3 is compiling perfectly now.
Thanks for your help.
I noticed that the default values for ATC_RATE_RP_MAX and ATC_RATE_Y_MAX are both 18000. However, the range of values for these parameters are 90000 to 250000. I know that these values are variable rates for flight smoothness. Is it safe to bring up values to 90000 or more? Thanks.
Willy,
Leonard and I just reviewed the range for the ATC parameters yesterday and we've fixed them now. I think it will take a mission planner release before they appear on your computer or maybe the mission planner will update it's defaults without that, I'm not totally sure. In any case, the new range is below:
ATC_RATE_RP_MAX: 9000 ~ 36000 (i.e. 90deg/sec ~ 360deg/sec)
ATC_RATE_Y_MAX: 4500 ~ 18000 (i.e. 45deg/sec ~ 180deg/sec)
It's safe to make the values much higher. They will simply not have any effect if you make them too high because the vehicle speed will just not be limited any more.
Thank you so much, Randy. Anyway, i have kept my values both at 18000 and tried again AC3.2-rc3 today. I did several auto flights with spline waypoints. So far, flights were smooth and no issues...ascending and descending between waypoints were great. I also tried Loiter circle - it's simply amazing! Again, i have so much respect and appreciation for all your efforts and hard works.
