ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • Similar behavior in the attached log, between 15th and 16th min.  in my case copter went into the "alt hold" and started drifting with the wind and would not respond to any stick movements, until I put into stab mode, only after that I regained control.
      2014-08-01 02-16-55.7z
  • T3
    Hi all,
    there seems to be an "error" in Mission Planner (1.3.7) re Log Analysis of 3.2rc4 logs. I get the following error message: "Unknown mode in TestPitchRollCoupling: POSHOLD" and "Bad input file". Maybe MP 1.3.7 only searches for "Hybrid".
    Best regards,
    Thorsten
  • I only have the log file, I'll run another test by varying the parameters. then we'll see how it goes.
    meanwhile, thanks
  • Has anyone tested 3.2 on a traditional heli yet. I am extremely interested in the EKF on a traditional heli.
    Great work dev team.
  • After a few more flights on rc4 i'm seeing error 16-2 & 16-0. I calibrated compass after upgrading to rc4.
    What is this? here are logs
      Raph,
           That's the EKF Check (which also checks inertial nav in case you're not using EKF).  It seems like we've set the checks to be too strict.  Can you set the BAROGLTCH_DIST to 500 and the EKFCHECK_THRESH to 0.8?
           Hope this helps.
      • Just noticed that when loaded with rc4, calibration procedure returns different numbers every time I try and some values differ a by 20-30 points.  In comparison, when loaded with 3.1.5 I get more or less the same values every time I do calibration. Tried 2 different mag/gps combos so far... (if it makes any difference I use telemetry module when doing my calibrations)
        • same here - I tried 4 times and all 4 were different. No adverse affects (yet) during flight, though.
          • I think this is where the 16-2 comes from.... magnetometer is not getting calibrated correctly.... either MP fault or the way rc4 handles/provides data from mag to MP during calibration. so when the new EKFCHECK function catches discrepancies it throws an error, in addition if the discrepancies are large enough copter looses direction control.
      • here is a log where it seems error 17-1 switched me to land. At the time I thought it was a radio failsafe. I was not flying with EKF enabled.
