ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
                  • 41k... that can't be it. Anyway I will get it right and get it on here tomorrow
          • COMPASS_EXTERNAL  was / is 1 by default fyi.
  • Every time i load the latest Beta 3.2-rc1 on Pixhawk i get a pre flight check gps not calibrated from apm.
    I have re-calibrated everything several times. I would like to get this build running in order to use follow me mode. Any suggestions?
    • @Andrew Nicholas
      Just not sure: Why 3.2-rc1? We are at rc-5...
      I'm now using M.P. 1.3.9 build 1.1.5346.13591 with pixhawk the error messages (e.g. didn't press the blinking red switch) bring wrong error message in mission planner.
      So what version of M.P. are you using?
      You talked about pixhawk and apm so which one are you referring to?
      Henri
        Henri,
        I've just tested and I'm correctly seeing the "Arm: Safety Switch" message when the safety switch is not pressed but it also arms correctly when the safety switch is pressed (i.e. not blinking).  I'm using MP 1.3.9.1 build 1.1.5350.14145 which is the latest beta release.
        I guess this is different to what you're seeing or maybe I'm misunderstanding the issue?
        • Thank you for answering Randy.
          I didn't fully understand Andrew Nicholas's query:
          "Every time i load the latest Beta 3.2-rc1 on Pixhawk i get a pre flight check gps not calibrated from apm"
  • Hi dev team and testers,
    Tested version 3.2 RC5 on APM 2.6 and Pixhawk. Works very well except in a fast descend, straight down, in Drift mode my Tarot 650 almost became unstable. I have not noticed this behaviour in PosHold. This video shows a test of Follow Me and PosHold.
  • Is 3.2 released?
    I see you have started with 3.3
    "Author: Randy Mackay <rmackay9@yahoo.com> Date: Mon Aug 18 12:56:22 2014 +0900 Copter: range check ACRO_EXPO to be no more than 1 APMVERSION: ArduCopter V3.3-dev"
      Goran,
           No, we've branched though so that we can limit any further changes getting into AC3.2.  Our release procedures are documented here by the way although it's a bit technical.
  • I'd like to know if anyone is testing sbus2 with the current beta.  I have a Futaba R7008SB sbus2 receiver connected to a Pixhawk via a 3DR PPM encoder.  I've been happy using rc2-rc4 via the PPM Encoder.  I haven't had time to load rc5.  Thank you to the devs for what has been an excellent experience(for me)!  I would like to take advantage of sbus2 at some point.  I don't see any mention in this discussion relating to testing/experiences.  I don't mind testing this.  However, it would be nice to hear the feedback of others on the topic relating to 3.2.
