Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Luis,
You'll see some new features at least (like spline). If you're in no rush, I'd recommend waiting for -rc7 this weekend which will resolve the "false-positive landing check" issue.
My yaw behavior in missions is totally inconsistent. I have the WP_YAW_BEHAVIOR parameter set for follow GPS course. So it should be pointing ahead all the time. I make a mission with spline waypoints, say 10 of them. It flies the plan nicely, but the yaw is never doing the same thing. Sometimes it follows the GPS course. Sometimes it just points "over there". Sometimes it points at the next waypoint. The same happens when I use ROI. It will start off looking at the ROI. THen end up off in la-la-land. Why would this happen? I'm using the RC5 beta.
Terry,
Yes, it's gone I'm afraid but instead you should find that some of the pins can be used for buzzer and light without having to set the LED_MODE. Less pins can be used than before but still the buzzer works, GPS and Arming LEDs and at least one "motor led". I guess this means i need to update this wiki page!
Excellent work by all the developers, associated with Arducopter development. My flight tested parameters are attached mauy be very much helpful to the community. Working very well on DJIF450, 3DR Aluminium Quad frame.
Motors:
LD-POWER MT2212 920KV Brushless Motor CCW w/Black Bullet Cap for DJI Phantom Quadcopter Multicopter
http://www.goodluckbuy.com/ld-power-mt2212-920kv-brushless-motor-cc...
LD-POWER MT2212 920KV Brushless Motor CW w/White Bullet Cap for DJI Phantom Quadcopter Multicopter
http://www.goodluckbuy.com/ld-power-mt2212-920kv-brushless-motor-cw...
Arducopter 3.2-RC5, Aluminium X-Quad Frame, APM2.6, External Compas...
Props and ESC's used are;
Props:
9047 9*4.7 3K Carbon Fiber Propeller CW/CCW Special for DJI Motors
http://www.goodluckbuy.com/94-7-3k-carbon-fiber-propeller-cw-ccw-sp...
ESC's:
Afro ESC 12Amp Ultra Lite Multi-rotor Motor Speed Controller (SimonK Firmware) Version 3
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct...
Flight Report ArduCopter-3.2-rc6
Takeoffs and landings in stabilize, alt hold, loiter and pos hold. Everything looks great! Position hold is especially fun.
Didn't notice any twitches in/out of position hold, and twitches into loiter seem reduced over 3.1.5.
I did the compass calibration per the Arducopter calibration dance, and both times it complained of not having enough points. The second time through I told it to calibrate anyway, and the values seemed fine, and it seemed to fly fine as well.
Being a Mac user, I used VMware to run Mission Planner beta instead of APM 2.x so I could access the extra parameters in the beta. One thing about the name "PosHold" is that when you're using the audio prompts, its hard to tell "PosHold" from "AltHold" when the computer is annunciating it. "Stabilize", "Alt Hold" and "Loiter" are fairly distinguished from each other. Just an observation.
Great build!
Will try EKF next flight.
This is a delayed report of more testing against ArduCopter-3.2-rc6 from over the weekend.
I ran AUTO, DRIFT, PosHold and STAB with takeoffs and landings in each with no issues.
Two things I noticed:
I built a little HK 250 to entertain myself and put a Pixhawk on it. I didn't have much luck with 3.1.5. It took off fine but was obviously very overturned as it had a lot of shake/vibration. I lowered the PIDs and tried again but it shot off to the left so I ditched it.
Last night I loaded up 3.2-RC6 enabled EFK and set MPU as Leonard suggested. It took off quite nicely on the first flight but was still in need of tuning. It was stable enough for an auto tune which worked very well. The battery ran out shortly after the auto tune so I didn't get to fly it for long but it was obvious that it was flying quite well.
It's a much different thing to fly then any of my other copters and I'm sure it will be great fun. Thanks for your work and help.
Randy, I performed a flight for 4 minutes outside in backyard with NEO-7M in Serial 4/5 port and my 3DR LEA-6H GPS on a mass and have logs for you to review. Would you please look them over and tell me what I'm seeing between them both. Is the combination of NEO and LEA a good choice or should I try a different secondary GPS?
2014-08-30 17-57-22.rlog
2014-08-30 17-57-22.tlog
Randy, It seems I didn't download the .bin and .log file that is associated with the previous blog. I do however have another set for you to review.
2014-08-30 14-42-28.zip
164
165
166
167
168
of 262 Next
