ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • I continue to have the compass calibration warning even up to rc9. Is this because they are off by more than 45 degrees? If so is there a way to turn off just the compass checks so the rest are working so I can turn checks back on? See log. Thanks!
    14-09-14_08-45-46.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3701829221?profile=original
  • Sorry to possibly repeat myself. RCMAP_ for the first four channels doesn't behave correctly in -rc9. looks like everything is ok but:
    Assuming a JR9XII radio:
    Making a radio calibrate is incorrectly mapping channel.
    Beware that on take off (stabilize)
    Roll channel is offset badly, throttle is not at right values.. etc.. etc..
    Would be nice if the RCMAP was working as intended..
    Or if impossible, remove it all together.. As it stand it is an almost guaranteed crash on take off..
    Henri
  • Je Je I'm not the only anxious ;)
  • @Randy
    Hi, How far are we from the stable release of this code? Cheers, Mike
      When we stop finding issues!
      • Ha ha good answer! ;-)
    • +2 :)
    • +1
  • I've ordered a new GPS antenna: http://www.drotek.fr/shop/en/home/512-ublox-neo-m8-gps-hmc5983-comp... (I took this an not csg, because it's come from eu, costs only 1/3 (with tax from csg) and it's better to mount it on a rod - a little bit higher from esc, motors, ...)
    Has anybody some experience with this model part? I've read, that I must jumper the voltage to 5V. In main configuration this part comes with 9600 Baud / 1 Hz. Must I change this data? Or could I connect this gps without manual configuration to Pixhawk?
    Best regards
