ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • T3
    Randy,
    I made some initial tests on a slightly different copter/frame with rc10 and tested two RTL landings. The first landing was perfect but the second ended in some longer wobble before it finally disarmed. I guess the problem was that the ground was not perfectly level.
    Attached you find the log.
    Best regards,
    Thorsten
    rc10_landing_wobble.bin
      Thorsten,
      Looks like it sat on the ground there for 7.3 seconds before it registered the landing.  It got close to recognising it 3 times during that 7 seconds but the overall throttle was bumping up and down around 25% and this was throwing it off.  The first landing, as you said, went much better with it registering the land in just over 1 second which is about as fast as it can ever be.  It's certainly the overall throttle level that is causing the land check to not see the landing.. on the first landing it very quickly got the throttle down to about 15% while on the 2nd one it got stuck up at about 25%.  It's not immediately clear to me why there's such a difference... but I suspect you're right that it's he slight lean of the vehicle that it's fighting against while landing.  This could be keeping the throttle a bit high as it prioritises attitude over throttle.
      Thanks for the log.
      • T3
        Randy,
        I missed your reply. Thanks!
        I made serval landings since then and everything worked fine. But all were on level ground. So in most cases it should work as expected - especially since no one else reported a problem. I'll make some tests next week trying to reproduce the effect.
      Thorsten,
      Sorry, I didn't get a chance to review your log today but I'll get to it tomorrow.
    It appears that -rc11 is just a bit too big for the APM1 (on any frame type) and on the APM2, the TradHeli code isn't quite fitting.  I'll sort this out over the next day or so.  This doesn't affect the vast majority of users.
  • CPU load going crazy >2500%   in mission planner and APM planner.
    with firmware 3.2rc10 and 3.2rc11, if i disconnect GPS it goes down to around 15-20%
    video on bench
    Hardware : Pixhawk and 3DR GPS v2 nothing else connected
    dataflash from outside test & setup
    2014-10-05 13-43-52.bin
