ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Hey Guys ,
    I want to know if 12 or 16 channel PPM passthrough + PWM RSSI is supported on the pixhawk with 3.2..
    I have an EZUHF 8CH diversity Rx I would like to have 8 channels for control and mode changes, while the other channels will pass through the pixhawk for other uses...Is this possible with the current version ?
      AKcopter,
      Yes, it should work with AC3.2.  AUX1 ~ AUX4 can be used for pass through from the transmitter/receiver's channel 9 ~ 12 respectively.  You can switch AUX5 and AUX6 into PWM outputs (instead of the default Relays) to get two more by increasing the BRD_PWM_COUNT from "4" to "6".
  • T3
    Hi all,
    (I also posted this drones discuss - so sorry for cross-posting!)
    I am having some problems with compiling AC3.2. I am new to GitHub so most probably it is my fault.
    I successfully compiled https://github.com/jschall/ardupilot/tree/pullrequest-accel-filter (first results see here: http://ardupilot.com/forum/viewtopic.php?f=80&t=10155). I just found that the EKF gyro biases are much noisier compared to 3.2. Additionally, - especially in the beginning of the flight - there are often some twitches and/or jumps.
    Since I have no idea what differences I have to expect when flying master compared to 3.2 and for detailed analysis I want to base the patch on AC3.2 RC14.
    Therefore, I forked ardupilot (https://github.com/ThorstenDP/ardupilot_32RC14_3Hz_lpf/tree/ArduCop...) and included the patches. All is fine but I cannot select the 3.2 branch of the PX4Firmware repository to compile it and get the following error message:
    I set everything up again from scratch as well as on different machines (all Windows 7) but with no success.
    There was a recent change in the PX4Firmware repository. So maybe this is the cause.
    Any help or hint in greatly appreciated!
    Thanks in advance,
    Thorsten
      Thorsten,
      This is really a development questions so let's keep this on the drones-discuss@googlegroups.com list instead of here.
    @Vishakh,
    That error can come from the Tx/Rx going out of range but it can also be caused by the FrSky issue being discussed.
    @Alex,
    I've tested a bunch more of the D4R-II receivers that 3DR had sent me and it turns out that all the receivers 3DR sells now have been updated with the newer firmware which resolves this issue.  It's just one older one that seems to have the old firmware on it that exhibits this issue.
  • 3.2-rc14 crash.  Any insight would be appreciated.
    Just when I was gaining confidence in this setup it went bad in a hurry.  7 minutes in to the second flight of the day it lost gps which I detected as it started moving out of Position hold.  Looking back I should have chopped throttle right then but as I tried to regain control it shot of sideways at high speed and cartwheeled on impact.
    Quad with pixhawk and external gps/mag
    The first flight went well and was my first attempt at an auto mission analysis below:
    Log File C:/Program Files (x86)/Mission Planner/logs/QUADROTOR/1/2014-11-03 10-42-30.log
    Size (kb) 9674.7021484375
    No of lines 129491
    Duration 0:09:01
    Vehicletype ArduCopter
    Firmware Version V3.2-rc14
    Firmware Hash 3a292db7
    Hardware Type
    Free Mem 0
    Skipped Lines 0
    Test: Autotune = UNKNOWN - No ATUN log data
    Test: Balance/Twist = GOOD -
    Test: Brownout = GOOD -
    Test: Compass = FAIL - Large compass off params (X:-58.00, Y:12.00, Z:177.00)
    Large compass offset in MAG data:
    Z: 177.00
    mag_field interference within limits (10.25%)
    Test: Dupe Log Data = GOOD -
    Test: Empty = GOOD -
    Test: Event/Failsafe = GOOD -
    Test: GPS = GOOD -
    Test: IMU Mismatch = GOOD - (Mismatch: 0.58, WARN: 0.75, FAIL: 1.50)
    Test: Parameters = GOOD -
    Test: PM = GOOD -
    Test: Pitch/Roll = GOOD -
    Test: Thrust = GOOD -
    Test: VCC = GOOD -
    Second flight went well for 7 minutes.
    Log File C:/Program Files (x86)/Mission Planner/logs/QUADROTOR/1/2014-11-03 15-59-56.log
    Size (kb) 8112.34375
    No of lines 107922
    Duration 0:07:30
    Hardware Type
    Free Mem 0
    Skipped Lines 0
    Z: 177.00
    Moderate change in mag_field (34.31%)
    Test: Event/Failsafe = FAIL - ERRs found: GPS_GLITCH FLT_MODE
    Test: GPS = FAIL - GPS glitch errors found (1)
    Min satellites: 0, Max HDop: 99.99
    Test: IMU Mismatch = FAIL - Check vibration or accelerometer calibration. (Mismatch: 2.16, WARN: 0.75, FAIL: 1.50)
    Test: PM = GOOD -
    Test: Pitch/Roll = FAIL - Roll (-150.86, line 102979) > maximum lean angle (45.00)
    Test: VCC = GOOD -
    2014-11-03 15-59-56.zip
      Greg,
      The problem is a GPS glitch that Inertial Nav didn't ignore completely.  So the GPS Glitch protection caught the glitch but then after a moment it thought it had cleared and let the position updates flow through to the inertial nav.  This led to inaccurate velocity estimates which it tried to resolve by leaning over hard.
      The only things I can suggest are:
      1. tightening up on the GPSGlitch detection.  So reduce GPS_GLITCH_ACCEL to 800 (i.e. max vehicle acceleration of 8m/s/s) and reduce GPS_GLITCH_RADIUS to 170 (glitch of less than 1.7m are always accepted).
      2. a more radical solution is to switch over to the EKF which apparently recognised the glitch and did not try to use the GPS for the duration of the flight.  This can be done by setting AHRS_EKF_USE to "1".  The EKF seems to be fairly reliable but realistically it hasn't been through all the massive amount of testing for us to be completely sure that it's reliable.
      Thanks for the report and sorry about the crash.
      •  Randy,
        Thanks for taking the time to look and for the detailed response.
        Is there any reason to not combine suggestions 1 and 2?
        Is there anyway to determine why these types of GPS glitches occur?
        How do you suddenly drop to a 0 Sat number?
  • Hello everybody...
    Yesterday i had a new crash with my Hexacopter.
    Last month i used v3.1.5, now i´m using 3.2 rc.14 for a few days.
    Everthing was great, but my copter had a bad crash, when i activated the RTL Mode and it lands into the highest tree ón the field!
    Can anybody check my logfile please, i can´t found something who explain the crash :(
    https://www.dropbox.com/sh/2dzrrsscxnr3sgs/AABoD-WasKkvcOoTo60BsQFO...
    Best regards and thanks.
    Dominik
    Dropbox - Link not found
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      Dominic,
      The major problem is the GPS is only updating at 1hz.  This causes a huge number (81) of GPS glitches and four DCM Check failures as well.
      The vehicle refused to go into RTL once because of those glitches but the second time, at that precise moment it wasn't glitching so it allowed it.  It's no surprise that it wasn't able to do the RTL well.
      I'll add a to-do to add another pre-arm check to ensure the GPS is updating at the correct rate.
      I guess you didn't notice the LEDs flashing and buzzer going off?
