ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Well, you can also just dump the screws and just tape the case together, or use brass screws, or stainless, or aluminum.
        Take a normal magnetic compass, move it closely around the electronics and wiring in you quad/plane, see if there any major deviations on the needle.
        Both with power on, and off.
        If that remains pretty stable, you have some other problem.
      • I replaced the steel screws in the Pixhawk and GPS with brass screws. That way even my own screwdrivers, which have become magnetized over time, will have no affect on the screws.
  • Big offsets of compass is caused by residual magnetization of compass IC. I haved same problem with onboard pixhawk compass (high offsets values around 600-800). I rid of that by demagnetizing chip with modified AC 50Hz transformer, after that offsets are very low around 10 to 30.Hope it helps .
    Demagnetizer
    • @Randy, Sven, Bartek,
      This is VERY interesting and probably worth adding to the wiki. Miraculously I found my tape head demagnetizer and held it to the mag chip and made it much worse the first time, The second time I waived the wand around over the chip and voila! the offsets are now very good (101, 18, -4) and the compass is working perfectly. Thank you so much Bartek.
      • Could the compass becoming magnetized be one cause of flyaways? I didn't know this was possible so it's worth some thought and testing. In my case, having the GPS wires running over the magnetometer must have caused the residual magnetism and this could happen over time with less obvious causes and unbeknownst to the pilot.
    • Thank you Bartek, I'll give that a try. Somewhere I have a tape head demagnetizer (if I can find it) and I also have a big tool demagnetzer. I'll let you know how it works.
    • I think you demagnetized the chip to the point where it doesn't care where north is anymore.
      • Micheal does raise a valid point.
        I would be very weary of waving a high power de-magnetizer around sensitive electronics.
        Unless you have stuck a very strong magnet onto your APM, there is hardly any way to build up a strong magnetic bias.
        Just google "hall effect devices", see if you can really "de magnetize" them, or should have too ?
  • @Randy. Thank you.
    I did update to the latest Mission Planner. 1.3.12.1 build 1.1.5434.14510 (c8e0f3e1)
    The new "compass live calibration" changed somehow.
    The previous offset on this quad (done with "speedy live calibration") were: -65 23 36
    After updating mission planner and re doing the same procedure at the same location, the new offsets were:
    Test 1 : -52 19 47
    Test 2:  -53 7   47
    Test 3:  -57 21 38
    Should I continue or just leave it at the last one? I did hope to get constant values.
    But the first and last tests are not too far apart.. Which one to believe?
    Henri
      Henry,
         I think those compass offsets will be fine.  Those offsets are all pretty small and compared to the overall field length (which is likely around 500) a 16pt change should be ok.  I say "16pt change" because it looks to me like the Test #2's Y axis offset shows the largest change and it's 16pts from it's previous value.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
