ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      William,
          Yes, I tink MarkM is right especially if you're arming from the mission planner.
  • This may have been touched upon already. Have a start stop issue  in forward flight when in auto mode and guided mode. Did not have this issue in version 3.1.5 but showed up in 3.2 & 3.2.1 Beta. Same vehicle same settings other than the new features of the firmware.
    During forward flight the vehicle will all of a sudden jerk itself back to slow down or correct and then continue in forward flight. Almost like the Inner loop gains need tuned but does not seem to make a difference if you do tune.
    Was wondering if anyone else ran into this issue and new of a setting that corrects this or if this could be an issue of the secondary sensors that are now being used (seems to be creating issues from the blog notes)
    best
      This is most likely because of a fix in AC3.2 which stops the target point from getting too far ahead of the copter or maybe it's because you're using spline points?  If it's spline then I'd expect the issue to be resolved with AC3.2.1-rc1.
      It's probably best to include a log of what you're seeing so we can be sure.
      • Will be getting that to you. Not using spline points
    • Just for fun, run a log file through this app
      http://www.rcgroups.com/forums/showthread.php?t=2151318
      • Just ran through the app.
        Seems to be a very useful program. Only real issue it came up with was:
        Error: The total number of sustained loops 4000
        03/ APM Speed Error: This is above 5% of the total loops!
        Looked at the log bitmask setting and it was set to a very high number not listed under selections. Not sure if this can cause major issue but we set to default.
        Will be uploading the logs so you guys can take a look.
  • Pixhawk and hexarotor seems to behave properly (3.2)
    APM 2.5 and (3.2) behave properly on a quad.
    Would like to use the LightWare SF02 as an altimeter.
    added a file called etc/extras.txt onto the microSD card with this content:
    sf0x start
    mavlink start -d /dev/ttyS6 -b 115200 -m custom
    mavlink stream -d /dev/ttyS1 -s OPTICAL_FLOW -r 2
    But I believe this is more for obstacle measurement.
    Is there a way to use the SF02 as an altimeter?
    Thank you in advance
    Henri
      Henri,
      Instructions are here to setup the SF02 range finder.  No need for anything as complex as modifying the startup files.
      • Thank you for this link, Randy. Unless I am confused, this link shows how to use the analog output of the SF02 and use it for distance measurement.. (I may be wrong) The SF02 has a uart and a very nice processing of the analog data.
        In any case, not sure if the link you mentioned is actually used to get altitude (instead of the baro) in the pixhawk?
        Thank you in advance.
        Henri
          Henri,
          We only support the analog interface for the SF02.  The altitude is used for surface tracking while in AltHold or Loiter so it maintains a desired altitude above the ground, it's not used as a replacement for the barometer for the altitude because it still needs to maintain a separate altitude above home.
