ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • Here are the logs, I rolled back to 3.1.4 to get them, then went up to 3.2 rc1 and I am getting the exact same as above.
      Anyhow I got the logs, back to the initial issue, changed to GPS mode and it flew away from me,
      2014-05-12 18-54-40.log
      • This reply was deleted.
        • Thanks, got it, works great, I attached that log from 3.2 rc1 download but I assume its the same.
          https://storage.ning.com/topology/rest/1.0/file/get/3702756295?profile=original
    • I've downloaded the logs using APMplanner and it works.
  • Ok I just did my test this morning and I was impress, but first things first I'd like to thank all the dev team who patches this all together. Excellent job!
    Here's my assessment:
    1.  EKF rocks! there's a minimal descends when flying around. Same thing happen when you fly in ALTHold, Hybrid and Stabilized.
    2. Battery failsafe trigger ahead of my battery lipo.
    3. There's a twitch when shifting from inav to ekf and vice versa.
    4. The twitch in RTL is now solved!
    Test pattern:
    1. Arm in stabilize
    2. Take-off
    3. Switch to Althold
    4. Switch to Loiter
    5. Switch to Hybrid
    6. Back to stabilize but this time on EKF then repeat 3 - 5.
    Quad details:
    1. Flight controller Pixhawk with 3DR uBlox GPS with Compass
    2. emax 2216 810 kv motor with 10 x 5.5 properller
    3. 30amps esc
    4. I tried different mAh lipo batteries. 2200, 2700 & 5000 all in 3s.
    5. 450mm frame
    I'll post the log later.
