ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
            • That's what i got and I have the same problem.
  • There is a tab in the log window for clearing logs.3701736471?profile=original
    • Hi Masam, i am using the "latest" AC 3.2-rc1.  So far, it's handling the copter nice.  However, when i tried to download the Data Flash Log via Mavlink, it says "Timeout on read - Get Log" and the signal strength of the Mavlink as shown on the HUD goes from 100% down to 4%. Is this an issue with the MP or the firmware slowing down the telemetry data? Thanks...
    • Thanks so much Masam.
    AC3.1.5-rc1 has replaced AC3.2 in the Mission Planner's Beta Firmware's link.
    This is just for the next two days while we test this patch release to AC3.1.  Discussion of this patch release are over on the AC3.1 release thread.
    AC3.2-rc2 will be back in the Beta Firmwares link in a couple of days.
    • Lior
      AC3.1.5-rc1 not include hybrid mode. I've tried this afternoon. Waiting for ac3.2. Thanks randy
    • Hi Randy, did you removed hybrid mode on 3.1.5-rc1 ? today I've tried the 3.2-rc1 and I think everything is working and no problem, I tried stibilize, loiter, holdalt is good, and hybrid is perfect, also waypoint with autotakeoff, RTL, Guided and autoland is working well. and then this morning I upgrade to 3.1.5-rc1 and the hybrid mode is gone. I think  AC3.1.5-rc1 is updated from 3.2-rc1
        Yudi,
             Yes, we've had to take a short break from testing AC3.2 so that we can test AC3.1.5-rc1.  AC3.1.5-rc1 is actually a step backwards from AC3.2-rc1.  We have to release a patch to the current official version (AC3.1.4).  AC3.2-rc2 will be back in a couple of days.  Discussion of AC3.1.5-rc1 is over on the AC3.1 release thread.
        • This reply was deleted.
          • No, it's in 3.2 and higher.  3.1.x is a feature downgrade but has the new bug fixes.
