Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
If you want to refer to 3.2-rc1, the link I provided is the right one. The other more recent build weren't released as such and are "work in progress", not guaranted to work
3.2-rc2 is now strait from the beta download. Though don't know were "motor sync test" disappear?
Will test the rc2 shortly.
Henri,
that's actually AC 3.1.5-rc2 in the beta firmwares area so it's quite a step back. testing is appreciated but none of the AC3.2 features will be there.
Hi Randy,
When will be AC3.2-rc2 available?
Henri, Oliver,
It'll still be a couple of days I think. There's a crash report on AC3.1.5-rc1 that Jonathan will be investigating and once we're sure it's unrelated to the release we can pull out AC3.1.5 and put back AC3.2-rc2.
I flew another two battery packs out on the APM 2.6 Quad today.
Did an Auto-tune first before flying the previous days waypoint mission again. Auto tune seems to proceed well, the final values changed a bit but handling afterwards was much like the result of the auto-tune done a few months ago (which was a good tune).
The waypoint mission flew OK but it still had some slight pitch bumps between waypoints, and the loiter circle seems to be way under size.
A question. Where is there some notes on the flash logs PM parameters meaning ?
I noted that there are some 'hits' in INAVErr, NLon and NLoop log charts, particularly when in Auto waypoint mode, if they really mean what I'm guessing...
Martin
An explanation of the dataflash log output is in the following document. http://copter.ardupilot.com/wiki/downloading-and-analyzing-data-log...
Thanks.
Seems an incomplete document at the moment. INAVErr has no reference.
Others do, looks like the CPU load is high maybe.
Martin
Ah, I posted the wrong link. The log messages generated by the EKF is detailed at http://planner.ardupilot.com/wiki/common-apm-navigation-extended-ka...
yes, i have it on my list to update all the docs before the official release to reflect the changes that are going into AC3.2. It's a bit tough to balance everything at the moment. The AVC competition is also taking a fair bit of my time as I plan for my copter to pop those red balloon.
244
245
246
247
248
of 262 Next
