Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Hi Randy with Piksi .. will we get true cm level positioning? .. would this include altitude too or would we have use the onboard baro for altitude , one of main objectives for me is to fly around 500mm to 1000mm above a grape orchard without dropping and touching the vine rows and having a crash ..Like Kiwi fruit Orchards it is hard to use sonar , as the leafy canopy could not be reliable enough to bounce sonar off of , then you have the issue of at the end of the row you now have ground level , so maintaining a constant height above a leafy canopy on undulating ground is important to me .. ideas are welcome .. cheers Reuben
I don't think you'll get nearly the precision you're looking for, especially since you need absolute positioning, not relative. If I were you I'd look at a kinect (I heard that there is a smaller version available). Good luck!
M.
Reuben,
I haven't flown with the Piksi myself so I really can't comment on the accuracy. In arducopter we don't use the GPS altitude though so I wouldn't expect any change in alt-hold performance. It's a slightly tricky problem you have there.
@Rai, you are shadowing your your bottom GPS. I would raise it up to the level of the top one. As far as Peter reported at Drones Discuss, both GPS are working, the one with 2 Sats more does the job.
Thanks for the feedback gervais, I am working on getting both the gps level and farthest away from the other electronics.
- Rai Gohalwar
Rai,
what do you have after in the mission plan the third waypoint? If it's the last one, that's what it is supposed to happen. It should enter loiter (which if you have a plane it will be circling).
Regarding dual GPS I understand that it's currently not used (only logged). It's only planned to be used later. I'm interested in that as well, as losing GPS lock is fairly bad for what we're doing.
Best,
Mihai
Hi Mihai,
The waypoint mission was a 120 something waypoints with about 15 location waypoints and the rest were commands to do at those waypoints. https://onedrive.live.com/?cid=AEFE88FA8296FDFB&id=AEFE88FA8296...
Wait, so you are saying that the dual gps feature is not active yet as far as helping the copter loiter/fly better. If so, could you source your information. I need to keep records.
-Rai Gohalwar
For dual GPS being only informational at this point check 9b on top of the post as Phill says.
OK, then there are a few more things to check.
- if it's a plane, check the parameter that gives you the "tolerance" in hitting the waypoint. If it's too tight it may just circle around it.
- if it's a heli/multirotor then check that as well, but additionally check compass calibration - that causes circling if it's off - you can recalibrate (and check the parameters), or better yet try loiter and push it away (wind would do it).
Good luck,
Mihai
hahaha , sorry i forgot to make the doc public.
here is the new link
https://www.dropbox.com/s/nwzxdg12lr2wc2m/field%20mission%201.txt
- Rai Gohalwar
So when is AC3.2-rc3 be available?
221
222
223
224
225
of 262 Next
