Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Very nice scenery... too bad it's so jerky. :o)
Did you use a GoPro for this footage?
GoPro Black +
Hi Edgar
Is your GoPro hard mounted or with gimbal? Thanks.
2 axis gimbal, they are built into the front of all Disco Pro's
Thanks Edgar. Your video is amazing! I tried AC3.2-rc3 but i had some brief oscillations. Maybe... because my PID's were high?.. although, i was using the same PID's with AC3.1.5.
I wish i can achieve that kind of smoothness as shown in your video. Regards.
what is the parameter for enabling telemetry output on telemetry port 2 of pixhawk AC3.2-rc3. is there any change?
Ravi,
In case you have no luck, try setting SR2_PARAMS to something else than 0, ie. 50. Maybe you use all the SR1 values for SR2 parameters. (In case they are all 0)
Ravi,
I don't think you'll need to set any parameters, just connect a radio to telem2 and it should just work i think. There are some parameters to set the baud rate. SERIAL2_BAUD is the parameter I think.
Just noticed this (AC 3.2-rc3) - ACCEL_RP_MAX is by default set above Maximum (126000 vs. 100000max). Is this correct or should it be set at/below 100000?
