ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
          Mike,
          Ah, we removed support for the external I2C led for the APM2 to save 1k of flash space because we are critically low (it wouldn't load on the board at all).  I didn't realise that anyone had actually realised that the I2C led worked on the APM2.
          • Ah that makes sense, cheers Randy. Lol I only realised a few days ago and bolted it on - oh well.
            Thank you to you and team for all the great work on this project!
    • I did some tests with 3.2 rc5 today and I had few crashes )-:
      Copter is SKy hero x8 with pixhawk. It was flying perfectly, no problems with 3.1.5.
      Installed 3.2 rc5, calibrated compass and accelerometer and went out do do some tests.
      The first tests were take off in stabilize,  then flying in alt-hold, loiter, (with and without EKF) and RTL. No problems so far.
      Then I decided to try short auto mission with automatic take-off and few spline way points. At the take off copter immediately  flipped on its nose, one prop and gps mast got broken.
      After repair I tried another take off in stabilize, everything OK so far, switched to alt-hold and after few seconds copter started do drift and crashed. There was nothing I could do with RC.
      I had a quick look on log files, there were errors like:
      Test: PM = WARN - 1 slow loop lines found, max 7.53% on line 9650
       in both logs.
      I have no idea what went wrong. Any clue about the possible reason for crashes (hardware, setup, ...) would be highly appreciated.
      Regards, Jure
      59.log
      60.log
      • Well, the first crash at the take off can be probably related to the warning #1. It seems that the problem with full throttle is there also with the take off in auto.
        What is still a mystery is a crash in alt-hold, perhaps some bad vibrations?
    • 3.2-rc5:
      RCMAP_YAW, RCMAP_THROTTLE, RCMAP_ROLL and RCMAP_PITCH can be changed and save.
      However they are not functional any more.
      Not sure why.
        Henri,
             Thanks for the report.  I think it's a reporting issue.  So the roll, pitch, yaw and throttle controls are properly remapped internally but the output that we see in the mission planner's Radio Calibration screen doesn't show the change.  I've made a change so rcmap is reflected in the message arducopter sends the mission planner and it'll go out with -rc6.
        Update: unfortunately the change I mentioned above wasn't compatible with plane so I've had to revert it.  I think we will have to handle this in the documentation or ask MichaelO to modify the GCS to flip around where the green bars appear based on the RCMAP parameters.
        • Same seems for ResetToArmedYaw, set @ CH7. Can be changed and saved, but it doesn´t work. Maybe someone else can try it. Btw. checked the logs, no ERRORs reported.
          Regards
  • I Have a technical question ..  If you arm on top of a hill, baro sets altitude at zero .. you take off and fly to say 40ft then fly down into the valley below.. so now your baro altitude goes minus 40ft what would happen ? Would the copter think it landed, what would happen to the throttle ..or say you wanted to land at a lower altitude than you took off from ? these are scenarios I could see me doing as I live in very hilly country side.
    cheers Reuben
  • This reply was deleted.
        • I couldn´t hold on, and updated my -rc4 to -rc5 as well for a short try. My F450 PXV2 crash copter behaved very well @ ALTHOLD and POSITION HOLD. I noticed that LAND works very well out of these modes, no more hopping. Started in ALTHOLD and won´t use STAB  for this anymore.
          Thx a lot for the work,devs :-)
        Martin, Troy,
             -rc5 is not quite out yet.  It's ready to go but I was away today so I didn't push it to the mission planner.  I'll push it out there tomorrow morning.
