ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • H Style
        • Your frame looks to be extremely similar to mine (Xplorer Pro 500, see http://www.rcgroups.com/forums/showthread.php?t=1994987) - isolated sections and all.  Have been flying it with APM 2.6 and now PixHawk, firmwares from 3.1.xx to now 3.2RCxx. Absolutely rock-solid - I have always upgraded FW, started with default PIDs and then auto-tune, maybe 10 times in the meantime. Never a problem
          BUT I have always used frame type X - not H
          Maybe worth giving that a try ?
          • Yes very similar. Josh posted some settings that I'm going to try tomorrow. #2880
            I used H just because the picture of the frame on Frame Setup was most similar. All my other quads use X style. I could change to V but don't want to take it apart just yet. What problems did you find, if you set it to H style?
          • I plan to build a Cinetank too (with an APM). What is the difference between these configurations and what are the avantages of one over the other ?
    • This reply was deleted.
  • Today I was trying the ArduCopter 3.2-rc4 01-Aug-2014.
    Unfortunately the Spektrum Satelite was not working anymore. Back to 3.1.5 It was fine again.
    • Andre:  I am having similar issues.  Mine worked fine through -rc2, but it will not work with -rc3 or -rc4.  What are your symptoms? When did it stop working? I am back to 3.1.5, but I really need sonar...
      Mike
      • I only tried 3.1.5 and 3.2-rc4. With rc4 there were absolutely no receiver signals. Also in MissionPlaner I could´t find anything to enable the satellite or similar.
        I was only trying the rc4 because of this Issue: HDOP mixed up with PDOP I thought It would be solved in rc4 but it is not!
  • Using MP version 1.3.7 build 1.1.5307.24027
    APM 2.6 Rx: FrSky D8R-XP reflashed with the 27 mS software in CPPM mode.
    APM 2.6 with software 3.1.5 RCMAP for the first 4 channel works fine can remap the first 4 channels without problem.
    Then erase and reflash APM with V 3.2-rc4: RCMAP is confused and it is impossible to remap the first 4 channels?
    I think this is an "undocumented feature"
    • I'm trying 3.2-rc5 and can't remap my sbus channels with rcmap feature, no effect after setting, restarting, reconnect, and the same wrong channels are moving.. super frustrating.
