Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
X2 I used to trick the pixhawk to think my channel 6 was channel 8 [ via the receiver wiring ] just for this reason. But now I have a s bus receiver and can't do that so I basically lost a mode. I only have a 7 ch radio My vote would be auto and RTL
Yes a lot of people would love this added ..
I think adding the main modes would be fantastic
Auto, Simple, Trigger and RTL
+1!
Once you tune your ride, 6 is just wasted space. I would love to have 6 with the full range of options and tuning.
I think a new mode is in order after I blew all this money on this thing. The FTTBAGATMTRTL mode. aka Fly to the bank and get all the money then RTL.... mode
https://github.com/diydrones/ardupilot/pull/1139#issuecomment-56017020
The improvements made to this are now part of #1406. Any testers out there.
https://github.com/diydrones/ardupilot/pull/1406
lets re-ignite it ! How about it Devs would you re-look at implementing it ?
UPDATE to Dual GPS. I received my MAX-M8Q GPS and immediately soldier head pins to it and hooked it up to my Pixhawk. Ran a bench test all night and this morning looked at the status menu on the Mission Planner and noted that while the LEA-6H GPS held steady at 10 satellites with a HDOP around 1.5, the Max-M8Q was locked onto 18 satellites with a HDOP of 1.1.
Next step is to conduct a few flights and I will attach logs for DEVs to review.
More to follow.
I will be very interested to hear your results!
I have seen almost the identical stats you saw comparing the two gps's. However I must say I'm a bit surprised I haven't seen a huge increase in physical accuracy. Even with 13-14 sats and an HDOP of 1.4 I saw drifting 2-3 meters sometimes. Not often but sometimes. 1 was more the norm. I only had 3 flights on the same evening though .... I know it can vary a bit day to day. It seems the biggest advantage to the Ublox 8 is the acquisition times. On a hot restart I often have 8-9 sats by the time the pixhawk gets done booting up. Nice! But if I bought it strictly for position accuracy.. so far I'd be disappointed.
124
125
126
127
128
of 262 Next
