ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Isn't it down and to the left to disarm?
          • did they change something or is my memory going! LOL
            I could have sworn that I use down to the right to ARM or to DISARM before RC9.
            But trying it to the left, does seem to disarm it right away. Thanks!
    • I had a weird issue with FS_THR_VALUE as well (in -rc7:n if I remember correctly).
      When I set the Throttle failsafe value to too low (around 970) I got this error. I got rid of it, when I increased failsafe value to 985. (My actual link-loss failsafe PWM is 982) Normal throttle range is calibrated and working fine: 1000-2000PWM.
      Didn't make any sense at all. On earlier setups and older software versions I could set failsafe value to 920 or 910 without any problems, now I can't get below 980....
        Pekka,
        There haven't been any changes in this particular part of the code (as compared with AC3.1.5).  There is a minimum acceptable value on the FS_THR_VALUE but it's really low.  It's not allowed to be less than 910.
  • This reply was deleted.
    • I think I noticed the effects. I had a decent sat count but it was doing strange things in pos hold.
    AC3.2-rc9 is now available through the Mission Planner’s Beta Firmwares link.  We skipped -rc8 because just as it was going out, Tridge found and fixed a bug in the FRAM (see last item on the list).
    Changes from 3.2-rc7
    1) EKF reduced ripple to resolve copter motor pulsing (only affects people who have set AHRS_EKF_USE to “1”)
    2) Default Param changes:
        a) AltHold Rate P reduced from 6 to 5
        b) AltHold Accel P reduced from 0.75 to 0.5, I from 1.5 to 1.0
        c) EKF check threshold increased from 0.6 to 0.8 to reduce false positives
    3) sensor health flags sent to GCS only after initialisation to remove false alerts
    4) suppress bad terrain data alerts
    5) PX4 dataflash RAM useage reduced to 8k so it works again
    6) FRAM bug fix that could stop Mission or Parameter changes from being saved (Pixhawk, VRBrain only)
    #2's lower AltHold gains may reduce the motor pulsing some APM2 users are seeing but if not we may need to add additional filtering.
    This release does not included the fix to enable reset-yaw-to-armed-heading because it needs some more dev testing.
    Thanks for all the testing people on this thread are doing!!
    Copter: enable auto yaw control in most flight modes · rmackay9/rmackay9-ardupilot@fbf0698
    Added support in Stabilize, AltHold, AutoTune, Guided-Takeoff, Land, Loiter, OF_Loiter, PosHold, RTL-Descent, RTL-Land,
    • Randy,
      If you get a chance can you please take a look at the log I have attached. I loaded rc9 onto my Disco tonight when I got home from work so I could test it. After I flashed it I confirmed all of my settings were still good and also enabled ekf. Took it outside and tried to arm it and it wouldn't arm. Came in and hooked to the pc and it displayed bad ahrs. So I disabled ekf and it seemed alright. So I put ekf on my channel 7 switch.
      Went outside and had a good flight and wanted to check the video footage to do some more gimbal tuning. Did some tuning on that and went back out. Took off in stabilize and enabled ekf and everything seemed fine. I switched to poshold and started climbing straight up. I noticed it seemed like it was oscillating so I quit climbing and starting coming back down. About half way down I switched ekf off. As soon as I did it started flopping forward and dancing around. I managed to hit stabilize just before it hit the ground. Somehow though I got lucky and it landed surprisingly soft on it's feet.
      The other thing I have noticed is it seems like yaw hunts around a little bit ever since rc7 and rc9. I don't know if it is related or not.
      2014-09-11 19-16-31.log
      https://storage.ning.com/topology/rest/1.0/file/get/3702517694?profile=original
      • I just noticed something else and I don't know if it has anything to do with the issue. When I flashed from rc7 to rc9, after the flash it plays the musical tones. The tones sounded just like it does when booting up. I flashed back to 3.1.5 and the musical tones were completely different and the normal ones that I am used to hearing after flashing. Could this be an issue that rc9 didn't flash correctly?
        I wanted to double check so I flashed rc9 back on and it played the normal musical tones like I am used to hearing when flashing the firmware.
          George,
          We will have a look at your logs.  I've had a quick look but some on the dev team are more familiar with the EKF so I hope they'll help me out.
          The list of sounds are on this wiki page.  My guess is you heard the new IO board firmware sound.
          • Randy,
            I couldn't hold back and flashed rc9 again. This time making sure I got the correct tones after the firmware flash. I haven't tried and probably won't try anything with ekf enabled for a little while but it is flying remarkably well. When I flashed rc7 and rc9 when I didn't get the correct tones it was twitchy and the motors seemed to be noisier, I also noticed that the yaw would hunt around when in poshold.
            For now I am going to write it off as a bad flash. Hopefully my log proves to be useful for the devs.
