ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      Manu,
      The code's available in the ArduCopter-3.2 branch in github.
    • T3
      Hi all,
      I also had to reduce loiter_jerk. The range is 500-1000. I reduced it to 500 but it could still be smoother. Can it be reduced below 500 and if so what would be the risks?
      Thorsten
        Thorsten,
        I'd guess it'll just get sluggish.  I haven't tested it very low but I'd be surprised if it became dangerous.
        • T3
          Thanks Randy!
          I'll make some tests over the weekend and report.
          • What is your setup? I also fly with 500, it improved a lot from default setting.
            • T3
              Hi Manu, I have some hexas also with low kv 360-590, 15''-17'' and 4S.
              Not sure what the default value was but 500 is better but I'll give some even lower values a try.
  • with rc10 and previus Loiter_turns in a Mission is not working probably.
    The kopter is just turning CW at the Point, regardless the Parameter i set in the Missionplaner. pleas can you check this?
    2014-09-25 10-04-51.bin
    • LOITER_TURNS works only if Dir=0 and only clockwise.
      • not in my case, in rc 9 loiter_turns were working as you mentioned with DIr=0, but now in rc10 it turns around with out any radius from the circle parameter. Regardless of the parameter in mission planner at the Loiter_Turn line.
  • I don't know if auto missions are being tested much in 3.2 but it looks like the wiki needs some updating. It doesn't match with what is seen in the latest mission planners. I would like to test auto missions in rc9 as everything else seems very solid but I'm hesitant to enter some waypoint or takeoff incorrectly. I opened a thread about it on the forum but so far no responses.
    http://ardupilot.com/forum/viewtopic.php?f=100&t=9687
Aug 25
