ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    Throttle spike after vibration.
    Just had an unnerving uncommanded full power climb which seems vibration related:
    3701856187?profile=original
    Would EKF catch this king of thing or is there another safeguard?
    Not sure why I suddenly got vibration, resonance between motors/props perhaps, nothing is loose, props fairly well balanced but they are 15" on lower Kv motors. The vibration seems to absent earlier and later in the log?
    2014-10-21 08-08-23.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3701856060?profile=original
      Graham,
      Comparing the Alt from AHRS2 (EKF) and CTUN (DCM) it looks like even the EKF would have had a hard time (both show a massive drop in altitude).  Still, I suspect the EKF would have handled it a little better and also the EKF is able to tell us when it thinks things have gone wrong.  We don't take advantage of that yet for the Z-axis but we do for the horizontal.  I imagine in AC3.3 (?) we may add some additional safeguards to catch these situations and maybe revert to a baro-only alt hold just to get the vehicle down.  I can't promise anything but we can try.
      3702527491?profile=original
        Thanks Randy, is there anything else I can do to mitigate this type of occurrence? Have had a few flights now with different damping mounts for the Pixhawk with no problem so far but would really like to avoid a re-occurrence, not good for my heart rate or the spectators' :)
    • If I am right you have 3g in Z and up to 2g in X axis. Have you check you don't have sync issue on your motors?
        Motors seem OK so far, how would I check for sync issues?
        The vibrations before and after are well within limits, just that weird section. I'm also trying different Pixhawk mounting insulation to see if there's a difference.
    • Now that is scary!
  • Does anybody know the current status of RSSI support on Pixhawk?
    I'm been searching and reading (even in Github), but haven't found any definitive answer(s) yet.
    Is this something that is already supported, or in the making in 3.2, or is it in a TODO queue somewhere (that I can't find)?
    The manual refers to PWM RSSI. Unfortunately, there are 2 flavours of PWM (servo PWM as EzUHF uses for RSSI I believe, and 'normal' PWM as FrSky outputs for RSSI). The manual isn't clear on which it's referring to, or if it's both:
    http://copter.ardupilot.com/wiki/common-pixhawk-overview/#Pixhawk_P...
    If it's referring to servo-PWM, then I must make a RC filter for my FrSky RSSI output, else just connect it directly.
    • For frSky X8R, plug in the RSSI cable to SB on Pixhawk directly.
      Set following parameters: RSSI_Pin:103 and RSSI_RANGE:3.3
      • Does one need a RSSI filter for that?
        • MR60
          Yes a R,C filter to convert the PWM pulses into an analog voltage signal that can be read by pixhawk, but I do not know what are the advised R,C values.
