ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      I'm afraid we took the branch for AC3.2 after -rc5 went out.  We're already 2 months overdue on this release and although it's a small change, we have to draw the line somewhere.  For example just this week there have been 2 other small changes that people also asked to be included... it's endless.
      The delay between AC3.2 and AC3.3 won't be anything like the delay between AC3.1 and AC3.2 though.
      Sorry, we just need to get this version released and pushed out so all can enjoy it.
      • Hi Randy,
        Do you have any idea when you will give public release on the AC3.2
        Missionplanner 1.3.8 still gives me the AC 3.1.5 as public.
      • This reply was deleted.
          The requests like yours are many, and if we continue to be evaluated and put them in the code we will never release a new version, hope you understand.
          The important thing is groped to fix all the bugs that may be present, then release.
      Yes Jan, is a known problem that I've already reported, it will be fixed after the release 3.2.
      • hi Marco, i look  you YouTube video  hexacopter  3.2b fail  while rotating around its axis and motion along the circle. https://www.youtube.com/watch?v=7WeOfKgdrP8
        its wrong works of ahrs_gps_gain=1 level correction?
        Problem is located?
          Hi Alexey, the problem is still under investigation.
          However i did subsequently many more flights without this thing happen.
          The board stop logging during this issue, also via telemetry, this is the thing to investigate.
          Unfortunately during this crash I did not realize that for an absurd reason I had a lot of vibrations to the board, I think this may have knocked the inertial corrections.
          Unfortunately during this failure I was flying very low and I have not had time to try a recovery in Stabilize or Acro.
          After that I isolated the vibrations and I have not had this problem.
          • I thought that because of the acceleration in turn had a tilt of the horizon, this effect is often observed in the "arduplane" in models with high torque. The best way to find it - use the OSD record. It is easy to compare the real horizon of the camera and the horizon of the autopilot. as a result of acceleration  the horizon may to be tilted to 30 degrees, this value was added to the angle required for braking, resulting in an angle of 75 degrees has appeared crucial to keep the altitude.
            I apologize in advance for wasting your time if you find my guesses delusional
    • Several have complained about this in Alt hold, the response to stop after moving in althold to a stop is a bit abrupt. Seeing your speed right before probably was just not high enough from the ground to right itself prior to the crash
  • In 3.2, is there a way to disable the internal compass? The Pixhawk is mounted yaw180 deep in a carbon fiber H-frame with esc power cables running on either side,etc... It seems as though the internal and external compass are working together for heading information and that is probably not a good thing for this particular setup. I can't seem to find a param to disable it.
      Michael,
            There's no way to disable the internal compass I'm afraid.  Only the primary compass is used which will be the external one by default.  There's no fusing of the compass values although that might make sense for us to do that eventually.
           So in your case, I think you just need to worry about the possibility of the external compass failing in flight and it switching over to the internal compass.
