Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
EFK was / is off for me too ! see the attached logs
but strange pulsing sound from motors in alt-hold and pos-hold.
any help ?
Thomas
2014-08-27 19-52-49.log
short update !!!!
after 27 test flights with different parameters i decided to lower rc_speed from 490 to 400 and the magic "motor noise" problem is gone :-) Video is smooth except very high speed. This time tested with and without EFK.
hope to get the fix soon for testing !
Thomas
Thanks for feedback.
Anyways, I see no interest of running >400Hz while the main_loop rate for pixhawk is 400Hz (and only 100Hz for APM) so the motor output would not be changed between 2 different loops.
Richard,
about hybrid (poshold), you can increase the braking rate PSHLD_BRAKE_RATE (default 8°/s)
I did many tests and 8 was my best compromise but if your copter is very stable and roll/pitch overshoots are very low, you could increase a bit that value (eg: 10-12). The idea was not to get a short and accurate braking (like loiter does) but a smooth one that looks like a manual braking
Motor pulses are maybe linked to the throttle controller that is tuned too sharply. Try to decrease P (and D) gains a bit. Your TC_Z param should not be too low neither (set it between 3 and 7)
If you are using a sonar, try to disable it and make other tests.
Julien
I changed PHLD_BRAKE_RATE to 17 and it still stops very smoothly. My quad is very heavy so the increase seems to work very well for me. I suspect a lighter frame would need much less.
I will work on the throttle control as you suggest over the weekend. No sonar.
Thanks for the detailed reply.
I reduced PSHLD_BRAKE_RATE to 10... 17 was too high.
re compass issue Log after APM P daily 2.0.15-rc1 Thought for sure it would be fixed because when I re-calibrated the compass ['s] it said both compasses have been calibrated. Did a pixhawk re-boot too. Still a no go unless arm check is 0
compass 1 id 2030116352
compass 2 -1
maybe I should be posting in APM P as well?
8-27-4-41.log
I've found the issue and it's been fixed in master so it'll all be fine once -rc6 goes out.
That's really great. I believe I had the same problem. I have done the Live Calibration Dance atleast 10 times, but it still would complain about Compass Calibration. I also have the 3DR external compass connected to the Pixhawk. (Running 3.2-rc5). Disabled the check in the end, and flew like a charm. Will retest once rc6 is out.
Hello Randy
as you requested on Github i've attached the logs for the inacurate Autotune issue 1337
As i was trying today to make new logs, my Hexa went crazy on first takeoff and crashed, don't know why and two Props broken.
So the files attached are not taken from today's test session but they are reliable not older then some weeks.
File "2014-08-03 18-31-56_315" is with Autotune in ArduCopter 3.1.5. The determined PID's worked very good.
File "2014-08-24 20-31-55_32rc5" is with Autotune in ArduCopter 3.2. rc5 . The determined PID's are not working so good.
for all other below the origin message for this issue
Hello @all,
i've updated my hexa from AC3.1.5 to AC3.2 rc5 and reset all settings to default (setup>reset). After calibration and all the other startup stuff i went out for autotune. unfortunately im getting complete different PID values compared to AC3.1.5
This are autotune PID values for AC3.1.5 working very well!
STB Roll 11.25
STB Pitch 11.25
Rate Roll P 0.0875; I 0.0875; D 0.0110
Rate PItch P 0.045; I 0.0450; D 0.0105
This are autotune PID values for AC3.2 RC5 working Bad!
STB Roll 5.29
STB Pitch 5.29
Rate Roll P 0.0350; I 0.0350; D 0.0020
Rate PItch P 0.070; I 0.0700; D 0.0130
if more informations are needed to solve this one please let me know...
ATT_Logs.zip
