Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
When you say "write" you're referring to the type in the Advanced settings of the Mission Planner?
Hi All, installed 3.2 rc5 yesterday from 3.1.5.....just magic. I operate a 1300mm quad running 130kv motors. Tested, stab, loiter, alt hold, auto and flight plan resume. No jumps now between modes, waypoint transition now super smooth. Had some trouble tuning the quad from wind gust disturbances so I decided to land and activate EKF. Wow, made a big difference to this machine, now super stable. Will try auto tune with EKF enabled next flight. Well done to all the Devs and flight testers.
GocGoc,
Thanks for the report.
There are some reports that the EKF can be a little twitchy in Loiter mode although Paul Riseborough (who created the EKF with Tridge) has a patch to resolve that. It's not a bug though, it's an additional filter I think.
EKF is already the default on Plane but for Copter we're going to leave it as the backup for AC3.2 but it'll likely be the default for AC3.3. So hopefully between now and then people can give it a try at a relaxed pace and we can sort out any issues that appear.
I've already reported this "motors twiching" with EKF, the discussion about this issue and the related patch is here.
EKF for Copter requires a very complex tuning to get good results, and with too high parameters (RATE_D for example) will highlight these issues.
At the moment i think the best solution is to leave it disabled and wait the fix.
Thanks Marco & Randy, appreciate it.
that patch will be part of rc7?
Jay,
Yes, I suspect so. I don't really want to include anything more except critical bug fixes this close to the official release but I think this one will probably go in and we will have one final -rc7. I guess I'd just like to see if any other serious issues come up in the next week or so before making the final decision.
Hi Randy, I noticed a little twitching in loiter only when I was commanded movement, in the hover it seemed to be fine. These 130kv motors are a little docile anyway. I will keep monitoring.
it s a good way to see a good and reliable officiel 3.2 !
Hi All,
Hereby a Set Auto-Tune Logs to identify the differences between V3.15 and V3.20 RC5 for those interested,
See the word file for explanations.
Erik
2014-08-03 12-42-00 Autotune-v315.BIN
2014-08-20 20-35-54 Autotune v320 RC5.bin
Auto-tune diffs between v3.15, and v3.20 RC5.docx
166
167
168
169
170
of 262 Next
