Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Thanks for the reply Randy. The sound I heard when I flashed back to 3.1.5 was the firmware loaded successfully and the one I am used to hearing when flashing firmware. The sound I heard after loading rc7 the one time I had an issue was the "startup ok" and the same with when I loaded rc9 last night it played the "startup ok" after flashing.
When I did the test with flashing back to 3.1.5 it played the "Firmware loaded successfully" and I remembered the tone sounded different when I had loaded rc9. So I flashed rc9 again and it played the "Firmware loaded successfully" tune.
Now I am unsure if I want to try rc9 again since it didn't play the correct sound maybe I had a bad flash? I am probably going to stay on 3.1.5 at least till after next weekend as I have an event I want to get some aerial footage with.
Here is a link to the video from the gimbal camera: http://youtu.be/OwWnn3woRCo
You can tell when the ekf was turned off and immediately made a hard right front turn.
Not sure what happened to the audio in that video. Here it is again with the audio working.
https://www.youtube.com/watch?v=PLEWFhHJVCo
With changes such as these:
a) AltHold Rate P reduced from 6 to 5
b) AltHold Accel P reduced from 0.75 to 0.5, I from 1.5 to 1.0
c) EKF check threshold increased from 0.6 to 0.8 to reduce false positives
are we expected to do more than simply update the firmware to the latest version?
In other words, is there some reset that must be preformed to be sure we're using the new defaults?
I'm still seeing a blank 'LOG_BITMASK' in my PixHawk with RC9 and MP 1.3.9 build 1.1.5346.13591.
I decided to do a reset (in termnal) using RC9.
Just sitting on my desk, no flight battery, but powered by my USB cable, after recalibrating my compass, accel's and radio, i seem to get constant:
PreArm: Check FS_THR_VALUE
And then when I try to arm constant:
PreArm: Alt disparity
I've had from 9 to 12 satelites, HDOP from 1.7 to 2.1.
Do I need more calibration or did I miss something?
Hi Rich,
I (as well as others) also experience Alt disparity warnings frequently. This happens to me when I plug the battery in when the copter is sitting on table and then move it to the arming position - a couple of meters away on the floor. Same as the velocity warning it should vanish after a while. If not then reconnect the battery.
Thorsten
I'm in South Africa.
Previously, I had up to 12 GPS sats during power up.
Lately, I only get a max of 8 sats, confirmed with my phone, and tablet.
Anyone else in Africa noticed/confirm this ?
Oh, my 3DR quad flies so well with APM 2.6, I will never "update" it :-)
maybe related to the solar flare !
http://www.swpc.noaa.gov/alerts/archive/current_month.html
Rich, yes, you could reset all your parameters and start from scratch. But it would be easier to just go into your full parameter list, and change those 3 manually.
Rob,
As I could have missed other changes, I think I'll do a reset. I'd hate to miss something.
Perhaps this should be mentioned when the final is released, other than trying to have everyone going through all the release notes and finding everything that has changed over time.
Thanks for your reply.
I still wonder about why LOG_BITMASK shows blank in the current versinos of MP, even with RC9.
137
138
139
140
141
of 262 Next
