ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        Have you checked with "Ublox Center" if your NEO8 is set correctly to "UBLX / 38400 bd, 5 Hz"?
        I've no problem, i've three M8 gps unit installed on VR Brain and Pixhawk, all works fine.
        • It came with a 6 pos to 5 pos cable. I assumed that was for use with apm 2.5 - 2.6. I used a 6 pos to 6 pos cable for use with the pixhawk that's correct right?
        • No I haven't. I did request it be shipped for use with a pixhawk and it seems to communicate with the controller because RTL seems to work.
          I have a Mac too so that's an issue for me running that Ublox Center. I wonder if I could check those settings with this http://download.cnet.com/CoolTerm/3000-2383_4-10915190.html I've used it to set up a spark fun wifely module but I'd have no idea what the commands are for the NEO8. Guess I'll have to try to somehow go this route if nothing else works.
          • Hey, where does one get the stuff to "set up a spark fun wifely module"?  My wife wants to know!  (Grin...)
  • T3
    Hi Randy,
    I am having problems with the landing detector from time to time (currently 3.2rc9): the copter tips over to one side - not a real flip or crash but not a nice landing as well. At the moment when I expected the copter to disarm the motors speeded up again - a little bit too much - and the it tipped over. Attached a log. The landing of the flight before was perfect.
    Maybe my landing speed is too slow?
    Best regards,
    Thorsten
    32rc9_landing_problem.bin
      Thorsten,
           I had a look at your logs and a chain of things went wrong with the landing detector.  The landing was a bit hard which threw off the althold controller a bit so it's throttle didn't stay glued to the bottom of the range.  This gave enough time for some horizontal position error to be created which led to the vehicle rotating (in roll and pitch) which led to the landing-detector thinking the vehicle was still moving.  It looks like it got stuck leaning at about 25deg and it would likely have realised it had landed within another second or so (see how the throttle out reduces at the end?).
          In any case, I have a patch that I'll test tomorrow that is a two-stage landing.  In the first stage it will relax the horizontal position control if it thinks it has "maybe" landed.  the "maybe" landed check is much easier to trigger than the full landing check.  It's also much less dangerous if it gets it wrong because it won't flip over or anything.  The 2nd stage will be the one we have now where it shuts down the motors and attitude control.
           If all this look ok, I'll put it into -rc10 this weekend.
      3702519162?profile=original
      Copter: init loiter target when maybe landed · rmackay9/rmackay9-ardupilot@6eefad9
      Applies to auto's land, land, loiter, pos hold and rtl flight modes
      • Genius! Can't wait to try out this patch!
      • T3
        Randy,
        perfect! I would be happy to test the patch tomorrow morning, if you could post a compiled version including the patch for a hexa (Pixhawk) somewhere.
        Actually, the landing was not hard. But the damping is quite soft, because I figured that the vibrations need to be pretty low for the long endurance copter to be (very) stable. Hence, this might have caused the "issue". Since, I solved some other issues I will also test some harder damping again.
        Thanks and best regards,
        Thorsten
