ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • yup. love previous "poshold"   ... straight climbing faster and hold position. because manual throtle control.
  • Fairly new to the PixHawk family here.   I have a Hexacopter that will fly away in any GPS dependent mode. (lat long on the FPV screen were exactly right with 8 to 10 sats)  In Stab or Althold she fly's fine.  In PosHold and Loiter she seemed to want to drift off sharply to the left or right.    I have glanced through the logs, but do not see anything that jumps right out.   The firmware was at RC11 and I upgraded today to RC12 with same results.
    Hoping someone else can take a look?
    2014-10-11 17-27-27.zip
      Henry, many such problems are compass error related and as we rely so much on the compass errors this can have a huge affect on navigational modes. There doesn't seem to be much to check or inform us of errors except for the 'Bad Compass Health' message which is quite non specific.
      Double check your compass installation, orientation and direction.
      Tune better your parameters and check the vibrations, RC12 is fabulous as stability and position hold if your setup is well balanced and right tuned.
      I'm sorry to read that many of you have problems, but I assure you that is not dependent on code, I've often shown that it is only a matter of having a good hardware setup and work well with the PID.
      After the "Autotune" you must always tweak the parameters, or the result could be an overcompensation that can adversely affect stability.
      Listen to the audio of my video, I show what happens after Autotune if the rate parameters are too high.
      https://www.youtube.com/watch?list=UUPcCCiqkWYZmvxVgHhDZDHA&fea...
      And here a well tuned hexa, in Position Hold, it's as if it were stationary on the table:
      https://www.youtube.com/watch?list=UUPcCCiqkWYZmvxVgHhDZDHA&v=T...
  • Randy I often fly in different locations, inside and outside the city, should I redo compass calibration or something if I leave compass-learning off when I fly in a different environment?
    Also, a bit off-topic but I've been struggling a long time ago to get rid of YAW Oscillations in both my F450 and my TBS Discovery now, according to the wiki the max for stb_yaw_p is 6, rate_yaw_p max is 0.50 and rate_yaw_i is 0.050. What does those limits mean? Any number above that isn't going to make a difference?
    There's a guy here in DIYDrones using 9 for stab yaw p and 0.8 for the rate yaw p and he notices a difference, could it just be him?
    Sorry to repeat my post, I've asked before and maybe you didn't see it
  • Please can someone help me to setup a Spektrum satellite with the AC3.2?
    With AC 3.1.5 it works fine!
    Of course the Spektrum ist pluged in to the "SPKT/DSM" Slot.
    There are any Parameter to set? I cant find them!
    André
    • Has no one an idea about the spektrum satellite?
      Who is using a spektrum on pixhawk with AC3.2?
      • I am using it
        • and how does it works?
          Is there any parameter to set comparing to AC3.1.5?
          I really tried everything but in AC3.2 there is no signal showing on the RC calibrating screen in the MP.
            Andre,
            Which spectrum receiver are you using?
