ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • Hi tried rc 14 on tarot 650 first time powered bad acc heath rebooted and was fine flew loiter/rth/stabilize all worked great very stable in wind
      Stuart
      • Hi stubugs,
        thank you for your answer.
        Can you share your param please, so i can see if there something is wrong.
        My tarot 650 has 380Kv 15x5,5 @6S4000 with rtfhawk and NEO-M8N GPS  with HMC5983 from CSG.
        Sven
        • heres my para but my 650 has a 4s 8000 390kv motors with 17 inch props
          stuart
          dpixhawk.rar
          https://storage.ning.com/topology/rest/1.0/file/get/3702771042?profile=original
          stuart
          dpixhawk.param
          https://storage.ning.com/topology/rest/1.0/file/get/3702771032?profile=original
        • I have a new tarot 650 too with rc12 yet, I do autotune and correct stab pitch and roll a llittle and good results, today y try with strong winds and fly well, less stable than calm day but firmly; I have 460kv motors and 15*6.5 cf props and 3s batt, but few test yet; try autotune it's great
          • Hi Cala
            i have tried a autotune a few days ago.
            link
            But it does not work properly.
            sven
            • Hi
              today i have test a few things to get the Tarot fying well.
              First i have done load the autotune parameter from rc13 flight. Then i do some Rate Roll P mod with CH6 to get good parameter.  The second thing i have tried, is setting up the GPS/ Compass modul higher to reduce MAG interference. Now it is 10cm away from the hawk and 14cm away from the ESC and ESC cable.
              Flying in Stab and AltHold is ok Altitude is a little bit unstable, but it was verry  windy today.
              But when i switch to PosHold Mode the copter drift away like  beginn of toilet bowling. I have no Idea what i can do now. Mabay could it be a GPS or HMC5983 Problem?
              Are they really full supported by 3.2 rc14?
              Here is the latest log where i try poshold a lot of times.
              Hope someone can help.
              Regards
              Sven
              • might be the compass is in the wrong orientation, I had that problem with my external  HMC5983. and it toilet bowled to the ground a year ago.
                If its in the wrong direction you do not have to move it but can use a COMPASS_ORIENT  param. etc
                I have a value of 8 which is Roll180 altho I have PX4 (sensor upside down) and not a Pixhawk
                Check the HUD in MP and see if it follows correctly.
                I have not analysed your log tho.
                • Did you have telemetry? Just curious if seeing the correct compass heading in the HUD is a way of confirmation the orientation is correct. It would seem so..
              • Here is the Logfile upload was not ok
                2014-11-02 16-52-49.log.zip
                https://storage.ning.com/topology/rest/1.0/file/get/3702901473?profile=original
