ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Hi All, installed 3.2 rc5 yesterday from 3.1.5.....just magic.   I operate a 1300mm quad running 130kv motors.  Tested, stab, loiter, alt hold, auto and flight plan resume.  No jumps now between modes,  waypoint transition now super smooth.  Had some trouble tuning the quad from wind gust disturbances so I decided to land and activate EKF.  Wow, made a big difference to this machine, now super stable.  Will try auto tune with EKF enabled next flight.  Well done to all the Devs and flight testers.
      GocGoc,
           Thanks for the report.
           There are some reports that the EKF can be a little twitchy in Loiter mode although Paul Riseborough (who created the EKF with Tridge) has a patch to resolve that.  It's not a bug though, it's an additional filter I think.
           EKF is already the default on Plane but for Copter we're going to leave it as the backup for AC3.2 but it'll likely be the default for AC3.3.  So hopefully between now and then people can give it a try at a relaxed pace and we can sort out any issues that appear.
        I've already reported this "motors twiching" with EKF, the discussion about this issue and the related patch is here.
        EKF for Copter requires a very complex tuning to get good results, and with too high parameters (RATE_D for example) will highlight these issues.
        At the moment i think the best solution is to leave it disabled and wait the fix.
        • Thanks Marco & Randy, appreciate it.
      • that patch will be part of rc7?
