ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    ArduCopter 3.2-rc7 is now available through the Mission Planner’s Beta Firmwares link.  The changes are in the ReleaseNotes but also listed below.
    Changes from 3.2-rc6
    1) Safety Items:
        a) Landing check made more strict (climb rate requirement reduced to 30cm/s, overall throttle < 25%, rotation < 20deg/sec)
        b) pre-arm check that accels are consistent (Pixhawk only, must be within 1m/sec/sec of each other)
        c) pre-arm check that gyros are consistent (Pixhawk only, must be within 20deg/sec of each other)
        d) report health of all accels and gyros (not just primary) to ground station
    (a) is the most important and addresses the “false positives” on the landing check that led to Marco’s crash and Sandy’s near crash.
    (b), (c) and (d) should catch any IMU failures that happen before take-off like the ones Artem say.
    Note this release does not include the EKF smoothing from Paul Riseborough that Marco and a few others have asked for.  Tridge has his head down ahead of the Outback Challenge competition in less than 2 weeks and I can't merge such a big change without him.
    Thanks again to all the Beta testers that have put their vehicles at risk to test this release so far!
    • I was on rc6 but was having issues with shaking when changing to poshold or loiter with the gimbal. It would shake a little when not giving any input but initial movement after giving stick input it would really shake and you could hear the motors pulsing. So I figured I would try rc7 last night and reset everything back to defaults and do a new auto tune.
      I redid all of the calibrations and any of the settings I had changed before. The only thing I did differently this time was I set it as a "V" frame rather than "X". It is a TBS Discovery with the extended arm kit. Went out this morning and it flew decent in stabilize, flew decent in alt hold. So I gave it some altitude and flipped the switch for auto tune (Which has worked great at least 8 times prior). I noticed it was a lot touchier with where the throttle stick was or it would stop tuning. It was approx 3/4 of the way through the roll tuning and all of a sudden it dropped the left front corner and all but rolled over. I was able to flip it to stabilize and managed to somehow save it.
      I flew around in stabilize a little longer and landed. I am going to upload my log. The bad thing is I forgot to change the setting for what it should log so I don't know if all the info we need is going to be there.
      Going to change it back to 3.1.5 for some testing to see if it goes through auto tune without any glitches.
      I tried to attach the log but must have missed something. Will reply to this post to attach it.
      • I also just uploaded the last flight log with 3.1.5 to droneshare and also have it attached here. I checked the parameters list on droneshare and now with 3.1.5 it only has one marking that is in red which is:
        MOT_TCRV_MAXPCT = 93
        The couple that were marked in red on the rc7 log parameters had to do with max angle. Not sure if any of this has anything to do with what I seen. Just trying to put as much info out there as possible.
        Here is a link to the droneshare flight with 3.1.5: http://www.droneshare.com/mission/17082
        2014-09-06 09-10-56.log
        • @George Randall
          I had the same problem. Somehow they "set the max value" of MOT_TCRV_MAXPCT to 80. Mine was 93 as well and was flagged also.
          Henri
      • I loaded 3.1.5 on it for now. It is a little too windy now to try and do an autotune. I was messing around with the droneshare site and uploaded the log from this flight. I don't know how accurate their readings are or if these are items that I would need to worry about but they had a few things marked in red for the parameters listings. Here is a link to it on droneshare and if you click on the parameters button you will see which ones are marked in red.
        Auto tune on Droneshare with rc7
        • I did auto tune with 3.1.5 and all went well. Landed in alt hold with auto tune switch still on and disarmed. I then turned the auto tune switch off and re-armed. It took off in a hurry to about 2 feet and flipped over right on it's back. I had a hard time getting the motors to shut off even with the throttle stick all the way down and trying to disarm. I attached the log file in case anyone can take a look and let me know what might have happened.
          2014-09-06 15-07-32.log
          https://storage.ning.com/topology/rest/1.0/file/get/3702765815?profile=original
            Hi George Randall,
            Sorry I didn't see this. I have had a look and two things look strange here. The first is that it looks like your alt hold altitude didn't reset to your current value before you took off again and also your autotune values seemed to not have an effect past a point.
            I hope the new autotune will not have this problem (if that is what it is).
            I am looking over the latest alt hold to see to make sure it shouldn't do what your logs suggest the old code is doing.
        • @George Randall:
          Once you have an account on droneshare, how do you upload your .log file?
          Thank you in advance
          • Henri,
            Once you are logged in, if you click on your name at the top right and click on profile it will take you to the list of vehicles you have. Click on that vehicle and on that screen there is a box you can drag and drop the log file to.
            • Thank you for this George.
              I was looking for a button or an upload menu of some sort.
