ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Got the same result without Mission Planner
      • I use Mission Planner 1.3.10 Build 1.1.5369.11976
  • This reply was deleted.
        Esteban,
        It's definitely vibration levels.  Jonathan Challinger has recently added a new automated test of IMU variations between the two accelerometers on the Pixhawk and it seems quite good at catching the problems.  It claims a 1.13 m/s/s difference between the two IMUs.
        3702669003?profile=original3702668789?profile=originalBy the way, you may find that setting AHRS_EKF_USE to "1" makes it perform better because the EKF is better able to deal with vibrations.  The EKF is still experimental however so the safe official advice is to try and reduce any vibration in the frame.
  • today I try again rc10 with strong wind, just impressed, first time that I can fly with this conditions in stabilize mode for the moment., Land is working well again.
    • Has PosHold been renamed to Position between RC9 and RC 10 ? I had been using flight mode 16 "Pos Hold" and now it seems to no longer exist ??
        Sam,
        Any chance you've re-installed the mission planner from the .msi?  if "yes" then you've got an old version of the mission planner.  I think on the "Help" screen in MP there's a "check for updates" button that should hopefully get it up to a more recent version.
        • Quite funny, it was actually the "Check for updates" button that messed up my installation of MP 1.3.10
          Updated to 1.3.10.1 (Beta) and all is good again ;-)
      Dan,
      There seems to be a problem with the GPS messages (or the processing of the GPS messages).  Below are two pics one that shows good GPS message timing (Column C shows the timing and all messages are 200ms apart = 0.2 seconds = 5hz).
      3702521964?profile=original
      In your log however the timing on the messages is not increasing properly at all.  Which GPS are you using and is there anything else unusual about the GPS's connection to the APM?
      3702521400?profile=originalBy the way, it looks like the GPS Glitch protection was disabled on this vehicle.  I don't think there's ever a good reason to turn it off and it would have caught the problem immediately I think and not let the vehicle take-off or switch into an autopilot mode.
      Thomas,
      I've made some fixes (here and here) which should ensure there's no "I-term build-up" before take-off.  This will go out with -rc11.  I'm almost confident that the next release candidate will be the last one.
          Adolfo,
          Thanks for testing it out.  I haven't completed my analysis but part of the problem is a bad tune and/or a bad center of gravity on the frame.  Is there a camera on the front perhaps that makes the vehicle nose heavy?
          3702768320?profile=originalThere's also significant overshoot on the Roll so maybe the Rate Roll P is too high.  Have you given AutoTune a try?
          3702768301?profile=original
