ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Cool! Thanks!
  • With RC10, my OSD will not display data unless I unplug it and plug it back with each flight.  Is this related to RC10 or something else??
      Pedals2Paddles,
      I don't think this is related to -rc10 (or even AC3.2 vs AC3.1.5).  It's more likely related to the SR0_ and SR1_ parameters.  These are all zero by default meaning that GCS or MInimOSD must tell AC what update it wants for all the data streaming out of the telemetry link.  Perhaps your MinimOSD is not waiting until the board has compeltely booted before making that request.  A work-around would be to set the update rates manually using the mission planner.   The parameters can be foudn in the Advanced and Full Parameter Lists.
  • Log from 3.2 rc12 on Tarot 650 quad with following specs:
    APM 2.5 (no external mag)
    SunnySky 4110S-25 340KV motors
    HK Multistar 45amp ESC running SimonK firmware
    Props - 16x5.5 CF
    Battery: 6S 5000mAh Zi[ppy Lipo
    Performed well; did not test any Auto or mission functions, just Stab, AltHld, PHold, and Land.
    Would not let me upload log file as it is too large...
    • Link to video: http://youtu.be/Q7g8a6goDIg
      • can share minimosd firmware? small font
      • Jim, I really enjoyed it. Did you tune parameters through auto-tune or you used default parameters ?
        • Auto tune and then lowered them further.
    • Jim great to hear about your flight with RC12,Try to upload the telemetry log file or the flash log file. Don't worry about the size, it should be less than 10MB.
    • Added log file zipped...
      2014-10-10 10-04-36.zip
