Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Hello,
Your first issue with loss of GPS has to do with the use of 1.3Ghz 800mw video Tx. This interferes with the GPS reception as I have experienced myself. Since then I fly with 5,8Ghz video tx and all is fine. 800mW is relatively a huge power in comparison the the received GPS Weak signals. Look in my published blogs, I made an excel tool to help you define all of your radio/video/ telemetry frequencies to avoid interferences.
Your second problem could be a ppm encoding issue resulting sometimes in missed frames ?
Mmm, interesting. I've been using the 1.3 Vtx with the APM for two years now. But I did reduce the size of the tricopter arms which moved it closer and so that makes sense.
On the ppm issue I'll look into the settings in Opentx and the micro Rx.
Hugues,
Entirely correct with the GPS problem.
Gustav
Hugues
Could gps interfeirance come from a 2.4 ghz telemetry receiver / tansmitter? I recently bought a Taranis and a X8R receiver. I seem to now be having issues with pos hold and anything that needs gps. I'm starting to think it's the X8R is that possible? It is right below my gps.
ps Sorry I don't mean to impose on this thread... just seemed related and you might know. Thanks
There was a discussion about the X8R interfering with GPS here
http://www.rcgroups.com/forums/showthread.php?t=2225318&page=42
Thanks. I moved the X8R it made no difference so I don't think that has anything to do with my problem.
Gps 2'' and moved reciever further back on my t810
All good now no sats interfered with
Stu
Did you see a bad sat count prior to your change? I seem to see a decent sat and hdop just doesn't act like it. Maybe the sat data comes and goes with the interference? Anyway I will move the receiver and cross my fingers. Thanks guys
Hi Richard,
Yes, most micro processor/digital devices actually generate a bunch of "RF Noise"
And since the received level of the GPS signals are pretty much in the "Noise Floor", they are easily swamped by ambient RF noise.
Distance is your friend, just a few inches separation can make a huge differance.
Mike
Is it possible the prop spun loose on #1? I double check about every 3-4 flights as I have on occasion
found one to be slowly loosening up. I hear ya about being bummed.. :[
