ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
          hopefully the sats have a good navigation controller to avoid hitting each other...
          • How about apm counfiguration? Could you tell me the wiring for apm? Thanks
            • yudi, I will try APM at the weekend.
              See DF-13 shematic for APM:
              3692630152?profile=original
              compass cable is the same and goes to I2C port.
            • Christian! Another problem that I noticed is, a random flashing in the reception of the satellites, suddenly the satellites do not appear in Mission Planner and in less than a second, reappear again.
              • Admin
                @Winston,
                It looks like I missed setting one configuration parameter that controls the messages sent by the GPS.
                If you are using U-Center, you need to go to the Message View/MSG(Messages) and set UART1 On with a check in the box between "UART1" and "On" and put a 1 in the box to the right of "On"
                I found this Message parameter setting in the 3DR LEA-6 configuration file.
                The data stream appears to be pretty stable now in U-Center.
                By the way, U-Center does not appear to convert UBX transmissions as far as HDOP and the number of sats.
                Tom C ArduRover2 Developer
              • Admin
                @Winston,
                I believe that there may be a problem with the capability of the CSG M8Q to handle a Measurement Period of 200ms (5Hz).
                I too have seen the data stream glitches, when using U-Center, at a Measurement Frequency of 5Hz.
                Switching back to a Measurement Frequency of 1Hz (default) cured the data stream glitching.
                Also, the HDOP value appears to be stuck at 1.1 no matter how many sats are presently be acquired.
                PS: It appears that U-Center does not decode the number of sats and the HDOP when in the UBX (binary) mode.
                TCIII ArduRover2 Developer
                • Admin
                  @Winston,
                  Since I am using U-Center, and not the MP connected to my Pixhawk which at boot up will send configuration parameters to the GPS, the reason for the data stream glitches, according to Craig Elder, is that the GPS is sending back unnecessary messages that are eliminated by the configuration parameters sent by the Pixhawk. The reduced number of required messages reduces the GPS transmission overhead thus eliminating the glitching.
                  However, that does not explain why you are seeing the glitches in the MP assuming that you have the M8Q/N connected to your Pixhawk and are using the MP to communicate with the Pixhawk over MavLink?
                  Could it be that the present GPS configuration parameters being sent to the M8 by the Pixhawk firmware are not correct for eliminating superfluous messages?
              • Winston, did you connect via USB or telemetry? Sometimes I have a telemetry lag causing the numbers to disappear.
                So we have to check the GPS in CLI while connected via USB. (with 3.1.5 bcs 3.2 doesn't have CLI)
                If there appear lines like '.................................................' we really have a lag in GPS communication.
          • Many thanks chris...I will order one
  • @christian, so what i understand is Ublox-Neo-M8N is plug and play with pixhawk. all one has to do is connect GPS and compass (i2c) connectors. is that correct?
