ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
            • Ok I have it set to nearly-all now so i'll make some flights this afternoon and post back.
  • I'm having some problems with position hold on 3.2 pixhawk. Everything is working well including loiter. But position hold just drifts and does not hold. My droidplanner confirms that position hold is engaged but the copter flies like its still in alt hold or stabilize. Any idea why? I've included my latest log file.
    1.BIN
      FlyHigh,
           It will almost certainly be because the roll and pitch sticks are not perfectly centered.  This can happen if the radio calibration hasn't been done regularly but it can also happen if you're using RCMAP.  There's a bug in AC3.2 in that it's not using the correct RCX_MIN and RCX_MAX parameters when RCMAP is used.  The workaround is to set the range (on the transmitter) of the roll, pitch, yaw and throttle channels to all be the same, and then re-do the radio calibration and ESC calibration.  Sorry for the troubles.
      • Hrm ok I know for sure that the range of my throttle is different, not sure on roll pitch yaw. But I changed my throttle minimum so that my failsafe would kick in if my radio cut out and the throttle went below my raised minimum. I will try making them all the same and recalibrating my radio. Thanks for the reply Randy.
          FlyHigh,
          Just to be clear though, adjusting the tx ranges only applies if you've changed RCMAP parameters.  If you've left them as the default then this is not the issue.
          • Ah ok. I haven't changed RCMAP so I guess this isn't my problem then. Hrm
  • AC3.1.5 is not being shown in "previous versions of AC" of mission planner when installing firmware. i can see AC3.14. does anyone has any idea?
  • A few days ago I try again with Land switch from Pos hold and the copter not moving, when I switch to land, the motors stop and crash (near floor, no consecuences), It's possible that I had a false positive because the copter isn't moving? (I don't have the log this time) previous last landings I success, I'm not shure when fails, I'm going to try more.
  • I found what I believe to be an error in 3.2 but maybe its an error with pixhawk? I fly a quad. RC1-4 are my motors. RC 7 and 8 are gimbal and retracts. RC7 and RC8 will not currently function unless I press the safety switch. Pixhawk/apm should know I have a quad setup and only restrict 1-4 for the motors giving me access to rc 5-11 at all times.
    • This is not an error in AC3.2, but is by design.
      What you present does have some merit, and might be considered, however, it would be complicated to do, so I'm not sure if it will be done for the next release.
