ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      Hattori-san,
           We don't officially support the px4-fmu only configuration although we think it should work.  By the way, you can disable the need for the safety switch by setting the BRD_SAFETYENABLE parameter to 0.
      • Randy, thank you for swift response.
         By quick trial,It becomes better that ESC seems to be initialized, but not to become completion.
        So, I will go Pixhawk that is the best scenario.
  • i tried the Neo-7 GPS and compass module from hobbyking. it is giving a position error of 500meters. i really do not know why. although i get satellite count as 9.
    • Data format compatibility issue or maybe map datum mismatch. Can't think of anything else...
  • I tried the new 3.2 code on my traditional heli last time. Stabilize works, however ..
    Is it an intended feature that the tail rotor does not react in acro mode, when i move the yaw stick of my RC?
    I only tried it with a unplugged motor. Unfortunately, there are no logs because for some reason the code with enabled logs is to big for my APM2. With AC 2.9 the tail rotor reacted immediately on yaw commands though the code and behavior has changed a lot since.
    • Matthias, AC3.2 rc2 is completely untested on tradheli, so I'm not sure what is going on with your yaw.  I had to do a number of fixes before I try flying it.  I've got a Pull Request in for those fixes but I don't know if they'll make rc3.
      I put a warning out not to fly AC3.2 on Tradheli yet.
      • Ohh... this is indeed an interesting fact ;-)
        Thank you for your reply.
        By the way: How do you make changes to an already sent pull request? Creating a new commit in your branch stashing the old commit (or reverting it?) and then just synchronizing, or creating a complete new pull request?
        • You you mean you made a mistake that's already in a PR?
          I'm not sure of any clean way that can be done.
          I would probably create a new branch from up-to-date trunk.  Then cherry-pick the good commits from your old PR branch.  Fix the bad one.  Then do a new PR.
          I've not yet found a clean way to fix a bad commit.  Reverts end up being ugly, probably don't want them in trunk generally.
          I do wonder if you could revert the bad commit, then make a new commit with the fix.  Then merge all 3 commits into one (the bad, the revert, and the good) so only the good would show up.  You then have the option of making a nice commit message.  Then you can push to a branch on GitHub and force it to over-write the history.
            1) remove (revert) bad commit
            git rebase -i HEAD~10 (shows you the last 10 commits)
            delete the commit you don't want in the list. it will be as if those lines have never been entered
            2) merge the last 3 commits
            git rebase -i HEAD~3 (select the squash command, follow on screen instructions)
            then edit the list to squash the newer commits into the older commit
            3) making a nice commit message
            follow the on screen instructions to mark commits to be reworded. then save, and you will be presented with each of these commits to reword to enter the new wording.
            If you only want to fix the last commit use git commit --amend
            git rebase with the squash feature allows you to rewrite your git history, it just gets difficult if you have pushed to master. In this case you just need to accept the mistake and push a commit to avoid everybody needing to do a forced pull.
            • Thank you for the howto !
              I tried --amend.After synching with the github GUI 3 commits showed up (the old, the new and a merge), hence I returned to the original branch, copied my changes and made a new PR.. just in case .. now it's eye candy again  ;-)
