Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
I almost had a crash when I realized too late that I have zero control while the quad is in decent in RTL. Normally on decent I could 'nudge' the quad with my TX to make sure it landed without obstructions. Is there a setting in the params to allow for manual adjustments while in RTL???
I THINK:
LAND_REPOSITION, set to 1 to enable repositioning
excellent .....that was it ....thank you!
Your Welcome Richard
I finally flashed rc5 and re-calibrated compass and accel. I mainly wanted to give hybrid a shot. Stabilize seems to fly a little better but I still need to do auto tune. I really like hybrid. The only thing I wish and maybe it is possible is the climb and descent rate when in hybrid is slow like it is in loiter. Is it possible to change the climb/descent rates to where they would like it is in stabilize?
I was able to find in the wiki a little info for this parameter: PILOT_VELZ_MAX
Am I the only one that feels it would be best to have the copter climb and descend as fast in hybrid mode as it does in stabilize? With being able to fly as aggressively in hybrid mode as you can in stabilize climbing or descending at a slow rate can get you in trouble pretty quick with other objects, mainly the ground when flying low on terrain that is uneven.
Hi Julien,
Thanks for the response. Were you able to at least see a difference with tuning the VELZ param? I could deal with the throttle as long as it would be a little faster. Maybe logic goes against this but an example would be the flying I did yesterday was over uneven terrain with a difference of about 5' between highest and lowest points. I was flying within two feet of the ground to get practice following terrain. Stabilize wasn't an issue but with hybrid I almost crashed because it was too slow climbing. There are many other cases where this would fit in.
Some could say that hybrid isn't meant to be flown within close proximity but I would love to be able to fly in hybrid and know I am clear of obstacles and release the sticks if I wanted to rather than fly in stabilize and have to flip a switch to loiter mode. I know hybrid mode right now would really shine when doing aerial photography out in the open and plenty of ground clearance.
Now is not possible because the "Position" mode was removed from the code, but i think a good idea would be introduce it again because PosHold with the manual throttle could be very useful.
I think it was removed to free up space in the APM board, but don't understand why this choice should penalize those who use the new 32-bit board.
Jason's Throttle Assist is the other alternative.
My two cents...
Marco
I'm not personally too keen on bringing back Position Mode. I think Marco/Julien's suggestion to instead introduce Jason's throttle assist into these modes perhaps using the selection method from steveF11music will be ideal. It won't make it into AC3.2 but maybe AC3.3.
Issue for AC3.3 raised here.
That's funny, I would say the only thing missing from Drift mode is altitude control, so I'm looking very forward to PosHold as is. :)
I'm on APM, so I appreciate the concern for supporting the older hardware, for a while at least. At the same time, I don't want anyone to be "penalized"; has there been any thought put into building for different platforms where various features could be included or excluded with #define directives in the code, or a similar approach? It may be more work, but might help people on Pixhawk from feeling like people on APM are holding them back.
172
173
174
175
176
of 262 Next
