Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Not a problem. It took me a little bit to find it but I remembered seeing the drag and drop box when I setup my quad on there. Just couldn't remember where it was.
Here is the log file.
2014-09-06 07-29-52.log
I have a question about RC7 and this release note:
So does this mean we should not fly with NavEKF enabled in RC7?
No, you can use EKF but there's this little "motors glitch", that's all.
Thank you for the clarification!
I just updated my Pixhawk to RC7.
Sitting here on my bench, I get "Bad Gyro Health" after the update.
So I tried to do a accel recalibrate. This seemed to work ok in RC6, but now it fails.
I see the following messages in Mission Planner's Messages window after an accel recalibrate:
Place vehicle level and press any key.
Initialising APM... Place vehicle on its LEFT side and press any key.
Initialising APM... Place vehicle on its RIGHT side and press any key.
Initialising APM... Place vehicle nose DOWN and press any key.
Initialising APM... Place vehicle nose UP and press any key.
Initialising APM... Place vehicle on its BACK and press any key.
Initialising APM...
Offsets[0]: nan nan nan
Scaling[0]: nan nan nan
Offsets[1]: 1.01 1.05 1.34
Scaling[1]: 1.02 1.01 1.02
Calibration FAILED
PreArm: Alt disparity
PreArm: Accels not healthy
THEN, I removed power from the PixHawk (I'm using only USB power at this point) and then tried a calibrate again. It seemed to work OK as you can see by the following:
Initialising APM...
Offsets[0]: -0.09 -0.16 -0.62
Scaling[0]: 0.99 0.99 0.99
Offsets[1]: 1.01 1.08 1.35
Calibration successful
I saw a brief 'BAD AHRS" message, but then that went away.
Am I OK to fly, or do I have something flakey?
Hi, Rich B
Now, I got the same issue "Initialising APM" with pixhawk, How did you solve it? can you help me?
Thanks!
I think the issue is that the board is not in a good state immediately after uploading the firmware. It's best (perhaps required) to power off/on the board after a firmware update.
I think your board is fine.
I thought EKF smoothing will be included in this release. :(
After upgrading to 3.2rc7, I'm not able to choose "Position Hold" flight mode in Mission Planner -> Flight Modes - no fm value on the combo box list. Full parameters page also does not show this flight mode in options column.
156
157
158
159
160
of 262 Next
